back brake pads destroyed!!
budd
Re: back brake pads destroyed!!
Post by budd »
sirch345 wrote: Mon Jul 09, 2018 8:57 pm Very interesting to hear what you have found. Not a brilliant idea though if you can reassemble the caliper out of alignment IMHO.
As you say though, keep an eye on it,
the 2 sides of the caliper are sealed with O rings and held together with M8 bolts but there are no locating pins so you get a small amount of free play around the bolts holes which allows it to be assembled slightly out of alignment, like I said it's my fault for not checking the pad retaining pin went through straight/square and pads were all free and not under any pressure. I think in the future I'll reassemble it all with the pins, pads etc and then release the main bolts the 2 halfs should then align themselves, once I'm happy they can torqued up to the required value, at the end of the day you it's a lesson learn'd.
Storm is now gone :cry: .
budd wrote: Tue Jul 10, 2018 9:22 am
Good to know about things like this, certainly something I'll be watching out for on the next brake caliper service I do where this could happen.
