Thanks for all Yr suggestions... A lesson learnt
Poor cylinder running and cam timing
- Commando77
Re: Poor cylinder running and cam timing
Well, I told you so. Tony M was closest and while it was 180 out on rear cams it definitely wasn't strong anywhere. Dumbo
read the manual again and took note what I learnt doing the mccts. For some reason I had ignored that and continued to time the rear pot 360 degs out. How it ran and produced 130 psi comp test with 4 valves just opening I don't understand. I repeated the test just before correcting the cams so it was real.
- alanfjones1411
If it's any compensation to you you're not the first,and won't be the last to do that.Glad you sorted out.
- Commando77
Good that you sorted it, sometimes you just have start over and redo.
So is it producing 160psi compression on both cylinders now
or at least close,
Could have been worse...
- Commando77
Around 158 front and 162 rear (ground exh valves), cold.
What's that, a hybrid!
That's more like itCommando77 wrote: ↑Wed Jan 16, 2019 9:50 am Around 158 front and 162 rear (ground exh valves), cold.
I'm glad you got it sorted in the end
I bet it sounds much better now as well
Good to hear is wasnt anything more serious!
- Commando77
As soon as it cranked with ign off the sound was different. Needless to say I'm happy it was nothing more serious but I knew it was mechanically OK and no valves or pistons were being hurt! Just pis*ed I'd ignored the bleedin' obvious and was Richard around with a tooth either way on the gears and stripping the carbs for the third time. ..and all for a noisy gearbox bearing. At least the bottom end is fresher though the shells were very good with little wear. Rear susp is also nice and fluid now with new linkage pin and needles. Cheers.
- Commando77
Don't know if this link works, just testing...
https://photos.google.com/share/AF1QipM ... 5BZjJXZTR3
Link works about as well as your first timing effort!
It's working now and your bike sounds spot on, well doneCommando77 wrote: ↑Wed Jan 16, 2019 8:39 pm Don't know if this link works, just testing...
Ah yeah I nearly forgot, you left of one of these [ at the end of your link. You had /url] when you need [/url] so almost there
Sounds good to me, best get it redlined on the road to check, though
- alanfjones1411
Sounding sweet
