Push the slide up and listen for the air being pumped through the chambers and let them go to make sure the don't just slam shut....again listening for the air movement.
Glad you got there in the endbigbadjonno wrote: ↑Sun May 19, 2019 6:57 pm Just an update on this, should anybody ever reference it in the future.....
I'd not got the diaphragms seated very well for the slides so they weren't opening.
Once I'd remembered the correct way to install them (with that goddam spring....) they were fine.
Originally I'd installed them by inserting the slides into the carbs, then the springs, then the caps. Nigh on impossible and hence the above result.
Much easier to insert the springs into the cap spigot, place the slide assembly into the cap with the diaphragm rib sitting on the cap, then inserting the whole kaboosh into the carb. Tricky to guide the needle in whilst holding back the spring, but much more reliable way to get the diaphragm to seat correctly.
D'oh.
PS why the hell is the fuel tap tucked way out of reach??
