Timing Chain Auto Adjusters....
trebor2001
Re: Timing Chain Auto Adjusters....
Post by trebor2001 »
Whilst changing the cam adjusters,with the Mileage on my bike a genuine 10000, one mechanic says, change the timing chain [ s ] other chap says no need, owing to the very low mileage, any thoughts ?
Leave the chains alone.....and find a new mechanic.... :beer:
8541Hawk wrote: Thu Oct 29, 2020 7:44 pm Leave the chains alone.....and find a new mechanic.... :beer:
trebor2001 wrote: Thu Oct 29, 2020 7:01 pm Whilst changing the cam adjusters,with the Mileage on my bike a genuine 10000, one mechanic says, change the timing chain [ s ] other chap says no need, owing to the very low mileage, any thoughts ?
without being rude ,the guys that told you that need there brains washed out,, change them or you will suffer :thumbup:
trebor2001
fabiostar wrote: Thu Oct 29, 2020 11:08 pm
So......are you saying, change the Chains, or just the adjusters ??
Best replace the auto CCTs with manual tensioners - and no need to change timing chains.
*** Read Me for New Members *** > Bike Maintenance and Upgrades/Modifications >
viewtopic.php?p=304638#p304638
Mark Krieger, APE, Bazza and Ade Whitmarsh's CCT's > viewtopic.php?f=16&t=22720
like everybody has said, the chains will last the life of the bike. I have no idea why any mechanic thinks that they need changed at 10,000 miles!
the CCT, is a risk, and strangely the risk looks to be worse if the bike is not used much.
Yes, change the ccts but leave the chain alone.
I've just been playing with a set of Ade Whitmarsh's ones, they're very fiddly as the dome nut is 17mm and the locknut is only 15mm. You can't slide a 15mm ring spanner onto the locknut. Because the locknut is partially obstructed by the fixing cap heads, you can't get a 15mm open ended spanner fully onto the locknut.
The open end spanner can only partially engage on the nut, increasing the chance of it rounding off.
