pipes under tank
Re: pipes under tank
northmanuk wrote: Mon Feb 07, 2022 9:53 pm i was thinkling if i sent photos am i correct i need to find a host site any ideas welcome thanks for all help so far
law
Ok the easy way is to add it as attachment. Start a new post, scroll down a bit & under the submit button you will see Options & next to that Attachments. Click on Attachments. Click on 'Browse'. It will now load your pics (this is assuming your doing it on a PC ) Select the pic & click add the file. Then scroll down a bit more, in a lower box it will have the file name & a click box to Place in line...
Hit the submit button & your pic will appear... You can always check first by clicking Preview first.
If you want to use a hosting site thats free I use Imgur. viewtopic.php?p=449062#p449062
I will add that all these things I do via a PC so not sure how it works on a phone...
northmanuk wrote: Tue Feb 08, 2022 9:09 am kev im still at the wind up record player stage :D
We have also now got "Add image to post"
See the RED arrow below, click or touch the picture to enlarge it (depending on which device you're using to access the forum).
northmanuk
Post by northmanuk »
i have connected all the pipes does the thermostat top hose point have a line connected to it
i have not got a 10mm pipe to connect to the tank but i do have the broad pipe with the moulded small pipe
and another small pipe from the rear cylinder to the fuel tap
and two large pipes from the carbs to fuel tap
one pipe from tank to petrol tap
No, the thermostat has one stub that is blank and has no hose connected. If you try to poke a piece of wire down it you will find it is blanked off.
northmanuk
t5hanks tony looks like the jobs nearly done carbs on air box on just got trumpets to fit long back short front lid on air box fill up coolant oils in new filter then try to start her (thats what im worried about oil leaks imm not confident any more still if it runs i will be very proud)six finger mechanics
and i got it back together lol :D
northmanuk wrote: Thu Feb 10, 2022 4:09 pm i have connected all the pipes does the thermostat top hose point have a line connected to it
That all sounds right to me :thumbup:
northmanuk
thanks chris just hope she starts and runs :thumbup:
northmanuk
forks legs now clean with original finish naff resprayed silver gone
new black foot pegs fitted
brake hoses removed they will be replaced with braided hoses
im due to fit new chain sprocket set paint rear sprocket carrier
calipers to clean and new pads to fit
so far in the skip are fender extender,bar risers,hugger brake lines. lol
rear brake system to replace
clutch hose to replace
should be finished by christmas i would have finished it quickly in my younger days :D
northmanuk wrote: Thu Feb 10, 2022 10:26 pm thanks chris just hope she starts and runs :thumbup:
I'm sure she will :)
