The RD400 drag bike
Re: The RD400 drag bike
Good tip on the RD LC group.
A good job you're going through it all Al :thumbup:
Frustrating afternoon on the RD, a few jobs need more parts, a few went ok.
Failed to bled the front brake as the bleed nipple is fecked.
So I moved to the clutch and there is no bleed nipple on that so
I had to Bleed it via the hose joints. I got the clutch bled eventually and then to test it I tried to put it into gear…. It doesn’t Image
Took the air shifter off and it is not that.
There is a reasonable movement on the shifter but there is no click of the selector drum Rotating into the indent.
I have the clutch cover off and I assume I need to get the clutch basket off to see what is going on.
AMCQ46 wrote: Tue May 17, 2022 8:01 pm Frustrating afternoon on the RD, a few jobs need more parts, a few went ok.
It might be different with the engine running regarding selecting gears, here's to hoping it is anyway.
No harm in checking what's going on behind the clutch basket I agree. If you're intending to be splitting the cases then you can check the gearbox components then. If you're not intending to be splitting them get the engine running and see how the gear selecting is then, that would be my suggestion :)
Good luck with it.
Whatever happened to the end of that bleed nipple :crazy:
I had to get a new 30mm socket to get the clutch off, but after that it came off easy enough.  I will need to work out where to source a new tab washer before I rebuild.
but first thing I can see is the little roller is missing that should sit over the pin on the selected actuating arm.
but unfortunately even if I put a bar in the gap, the selector drum is not rotating when the arm moves up or down.  the hooks that should catch onto the selector drum are not grabbing onto the ridges in the drum.
took more bits off and with the return spring off I could start to get it to select, but it needed the full travel of the selector arm, so the missing top hat roller is the problem, it is causing too much lost motion so the gear lever travel is not creating the maximum travel of the selector arm.
just need to track down the source of this part for a 35yr old bike.
fortunately the RD LC forum is helping a lot!
AMCQ46 wrote: Wed May 18, 2022 5:38 pm I had to get a new 30mm socket to get the clutch off, but after that it came off easy enough.  I will need to work out where to source a new tab washer before I rebuild.
Al, from the above post 4 out of your 5 photo's are not showing, and only half of your posting :eh:
Not that it matters now I guess as you have worked out what is wrong with the gear selecting :)
One of the guys on the RDLC Crazy forum has found an old roller and is posting it to me.
Happy days.
AMCQ46 wrote: Fri May 20, 2022 1:25 pm One of the guys on the RDLC Crazy forum has found an old roller and is posting it to me.
Happy days.
happy days result :thumbup:
Result Al
Happy days.
That's great news 8)
Where would we be without Motorcycle Forums :eh: :lol:
sirch345 wrote: Fri May 20, 2022 8:53 pm
Happy days.
farcebark is handy for a laugh and stuff but the one make Forums are still the go to for proper stuff :thumbup: :thumbup:
The missing jigsaw piece
AMCQ46 wrote: Mon May 23, 2022 10:03 pm The missing jigsaw piece
Not a corner piece, then. It's always easier to find out where the corner pieces go.
tony.mon wrote: Tue May 24, 2022 12:11 pm
:lol: :clap:
One of your better ones Tony.
Good to see the missing part I'm sure :thumbup:
Take dimensions Al before fitting :wink:
