just got her all washed and my mountain bike both wet and dirty in the past two days used that muc off stuff from halfords spot on stuff then just as i finished weve got hail stones in south shields bloody weather
- agentpineapple
today i fitted 12 titanium brake disc bolts, that means i can have another big mac meal
also refitted macs battery to my bike after 2 weeks in spain....
and i fitted a bright led park light bulb, but i also found out i have a wiring problem....no headlight or indicators, i reckon water has got into it somewhere, even tho the bike had a rain cover on for the last couple of weeks. i've checked the fuses, there ok, and the headlight flasher works so i know its not a blown headlight bulb...
Fitted manual ccts. Always amazes me that I can do it in less than an hour.
- tankslappa
That's an odd combination. I've become quite familiar with the loom during my alarm fitting.bigspanishmarty wrote:i also found out i have a wiring problem....no headlight or indicators, i reckon water has got into it somewhere, even tho the bike had a rain cover on for the last couple of weeks. i've checked the fuses, there ok, and the headlight flasher works so i know its not a blown headlight bulb...
The headlamp is fed via the dim/dip switch from the "off" side of the starter switch. That way the headlamp load is removed from the battery when you press the starter switch. The starter switch and headlamps runs off fuse C, 20A.
The indicator flashing output is the grey wire on the flasher relay. Stick a 21watt bulb between that and ground (with this ignition on) and it should start flashing. If so then the problem is probably the switch itself. The green on the relay is ground, the white/green +12v from fuse D, 10A. The same fuse runs the brake light, so might be worth checking that still works.
Fuses A is always live, the others are all switched from the ignition.
Unfortunately the one bit I really need on the circuit diagram is missing, the headlamp/sidelight switch... Damn always on EU directive wiring diagram! So I can't help with that part of the circuit. I don't even have the "passing" flasher on this diagram!
Anyway, it's probably water in the switches (or spiders and cobwebs as I had)... WD40 time!
- agentpineapple
cheers slappa
i'll have a little tinker with it....
Had the carbs off for a clean and tidy up
Took some pics of the nice stacks next to standard so you lot can drool over them lol
Refitted standard air box lid and snorkel but filled the foam with resin to harden and smooth it out and also to make the induction sound louder
Just waiting for postman to bring my new screen so I can tinker some more
good pictures to compare the length of the HRC bits vs standard, you can see how they flow more air and have the length to bump up midrange
looks like someone has had your carbs stripped down in the past as the joining plates on each side are painted black when the should be passivated steel
Finally got round to fitting the bellypan
yep did it last year lolAMCQ46 wrote:good pictures to compare the length of the HRC bits vs standard, you can see how they flow more air and have the length to bump up midrange![]()
Good pics there Lloydie, nice to see the comparison
Unlike the new avatar, arn't you a bit old for playing with teddies
Have Fun
Have Fun
that aint no teddy thats a evil little ewock that chases you
Otherwise known as the Mrs!!lloydiecbr wrote:that aint no teddy thats a evil little ewock that chases you
you poor git she soundsKev L wrote:Otherwise known as the Mrs!!lloydiecbr wrote:that aint no teddy thats a evil little ewock that chases you
mine just hides my bike keys
She is the light of my life, and also sitting next to me!
Kev L wrote:She is the light of my life, and also sitting next to me!
