Re: AMQ46's storm
Posted: Tue Feb 13, 2018 8:50 pm
god that wheel looks good
A bit late now, but may be Lloydie was thinking of treating Al for Valentines Day
First of all thanks Al for the update on the front and rear end of your Firestorm's suspension issuesAMCQ46 wrote: ↑Fri Feb 12, 2021 4:17 pm update on the back shock.
at the time of the original front fork conversion, I had a basic Nitron R1 (single adjust, no remote reservoir) shock, with remote preload adjuster, with a spring to suit fast road use and an occasional pillion, it was pretty good, but I was looking for the ability to fine tune it more to suit specific riding conditions.
I saw an ohlins shock for sale on ebay, with the full adjustability of remote hydraulic preload, Compression damping on the remote reservoir and rebound on the bottom of the shock.
Got it fully rebuilt & serviced and fitted the same spring rate i had on the NITRON, got it fitted and off we go......... but now I find a similar problem to what I was having with the front suspension, it is kicking me in the butt over any sharp edged lumps in the road, and if I back off the compression damping to soften it out it will start to wallow when I am on the gas hard on corner exit.
I suspect that the spring was slighly too stiff for me solo, but not by a huge amount, and I was disappointed that I couldnt get this dialed out with the adjusters. in my view the NITRON was providing better high and low speed compression damping compromise than the ohlins.
So I saw a Nitron R3 for sale here. that is the top spec with High & low speed compression damping, so given that I rated my basic NITRON, I bought that and sold the Ohlins.
It turned out that there was a bit of confusion and it was only the R2 (no Highspeed Compression adjuster), but we quickly adjusted teh price to reflect that, and the deal still went ahead.
I fitted a spring 10% softer than I used before (decided that there will be no passengers on the storm) and that's what's fitted now. the net result with the combination of softer spring and Nitron valving has got the back end working how I like it. I have compliance and control.
and I swapped the gold Gilles rearsets for some black ones
gold anodised things like Ohlins shocks are over rated!
