jbf955i wrote: Sun Apr 04, 2021 4:45 pm
Hi Mac,
Swapped them last summer and I've only covered arou d 400 to 500m since then due to lock down. I can't them off ebay, good reviews and lots of sales.
I've just checked the MCCT and it's tight, I don't know what happened to the other.
If the piston is bent, what kind of cost am I looking at? Bike isn't worth more the £1500 I guess!!!
On the up side, I'm half pissed and watching the GP, come Sam...
Sent from my CLT-L09 using Tapatalk
Hopefully the piston wont be damaged, if it's only bent valves,
Valves, valve guides & gaskets your looking at about £200 thats what it cost me some years ago...I gave someone £200 to sort it but that was private not a dealer...
https://www.bike-parts-honda.com/honda- ... 00/1/11510
Got the RD125LC running ImageImage
Duffy1964 wrote: Sat Apr 03, 2021 10:20 pm Thanks Chris, they have a bit of a following on fb and going up in value. Looking forward to playing with it Image
Ah I see Duffy :thumbup:
Duffy1964 wrote: Sun Apr 04, 2021 7:50 pm Got the RD125LC running ImageImage
Well done :clap:
There's nothing like a boost of enthusiasm for working on a bike you've just bought when, you find out the engine works 8)
jbf955i wrote: Sun Apr 04, 2021 1:39 pm Forgot the add the picture. Image
I have never known that to happen before. I have heard of the centre adjuster coming loose on a MCCT, but not the fixing bolts :crazy:
Are you sure you tightened the fixing bolts up tight when you fitted the MCCT's :?:
I hope the damage is not too bad for you,
jbf955i
Post by jbf955i »
Yes, all tighted. No movement at all on the other CCT, very odd Image
Mav617
Post by Mav617 »
I hung the front end off the garage joists and removed the forks. Drained and refilled with same amount of 12.5w oil (up from 10), cut the fork spacers with a pipe cutter 10mm, new KTech linear springs (9.0) arriving later this week and a pair of cheap chinese preload adjusters. Should sort the front a bit, now to save up for a new rear shock.
jbf955i wrote: Mon Apr 05, 2021 9:46 am
I agree very odd :eh:
jbf955i
Post by jbf955i »
Hi Mac,
Hi Mac,
Ive stripped the bike down and there is bend on the rod, picture isn't clear. I'll continue to investigate and let you know how it's looking, it's looking costly Image
jbf955i wrote: Tue Apr 06, 2021 10:29 am
Hi Mac,
Yep thats ferked...
Choice is either to strip & rebuild or replace the head compleat...
Radical move would be to swap whole motor...
jbf955i
Post by jbf955i »
Hi Mac,
Yep thats ferked...
On a scale of 1 to 5, how difficult is it to source and replace head?
Cheers for confirming its knocked pal.
jbf955i
1 if you know someone who has one.
5 if you need to trawl brakers/ebay.
Rears are quite common to find but as the fronts let go more often they are rare...
jbf955i
Post by jbf955i »
A 5 it is then
Thanks Mac
Could be a 1.
I've contacted someone I know who may have one.
+ I have a scrap engine that you either have the lot or just buy the head...
jbf955i
Post by jbf955i »
That would be great, thanks Mac
