It must be an age thing guys having to check our rings so often :lol: :lol:
well today as it was windy but dry i got kitted up and went out on the Triumph, or rather i would have if it didnt have total electrical death other than indicators horn and brake light :confused , checked the fuses, all ok, still no life including dash lights and starter button.. wheeled it back to the cave and chucked it against the hedge.. :thumbup:
fabiostar wrote: Sun Apr 07, 2024 9:35 am It must be an age thing guys having to check our rings so often :lol: :lol:
:lol: :lol:
fabiostar wrote: Sun Apr 07, 2024 3:48 pm well today as it was windy but dry i got kitted up and went out on the Triumph, or rather i would have if it didnt have total electrical death other than indicators horn and brake light :confused , checked the fuses, all ok, still no life including dash lights and starter button.. wheeled it back to the cave and chucked it against the hedge.. :thumbup:
How frustrating when you are all togged up and looking forward to getting out on the road, I hope it's not too much of a pita to locate.
Is there a cut-out tilt switch on it I wonder?
There must be something in the air, as my trusted cordless drill/driver started to malfunction on Friday, it has an intermittent problem of not working, right when I need it. Removing and replacing the battery gets it going again until I take my finger off the trigger,
At least you now know why the previous owner sold it....
Impressed that you have a hedge in your cave, though. There's posh- I barely have room for the spiders.
Lol iv a fair idea what it is..the ignition wires are short on them and cause problems..
fabiostar wrote: Mon Apr 08, 2024 12:40 pm Lol iv a fair idea what it is..the ignition wires are short on them and cause problems..
That's a good start Rob🤞🤞🤞
sirch345 wrote: Mon Apr 08, 2024 8:45 pm
Chris, Bit harsh given his problem...
That pun is bordering on Mons territory :lol: :lol:
MacV2 wrote: Tue Apr 09, 2024 7:23 am
In fact, as far as jokes are concerned. You could say it was a non starter 8O 8O
Pete yours was even worse specially the second time... :lol:
Poor Rob, it's like we are ganging up on him... First it's his non starter then his hight stumpiness.
Shortistism & Starterism...
:lol: :lol: :lol:
:lol: :lol: Apologies Rob, it was not intentional as some seem to think, I won't mention any names (just look above :D )
:lol: :lol: :lol: :lol: :lol: :lol: oh i wouldnt worry, it just means thats the triumph and the LC now with electrical death :eek2 :eek2
I’m sure you can lead the way Rob, the future is looming
Did a few bits on Rothburg.
Raided Franks stock pile & fitted a hugger.
Removed the lowered foot pegs & fitted some std ones.
Removed the gash blue bar grips replaced with some from stock.
Took the mahosive plate off & fitted a wee one, can get to the seat lock now. Was going to fit a bracket for the plate but found the undertray has been glued on with lashings of silicone . So that's a no go...Bah.
Took the fairings off to find the sidelight wire as it wasn't plugged in. Sorted that & had a mare getting the fairing to line up. Its a Chinees aftermarket job I had to enlarge the holes so I could use the correct shouldered bolts but the top right side bolt would not line up. Dug out a bracket from an F2 as they are steel not the ali as per the early bikes, bit of a tweak & it lined up.
Of course it started spitting so that will do for the day.
