Duffy1964 wrote: Tue Apr 09, 2024 11:32 pm I’m sure you can lead the way Rob, the future is looming Image
:lol: :lol: :lol: today i cleaned lots of wires and found a dodgy brown wire, ish so faffed with that, turned it on and bingo elsie is good, i then sat and watched it burble away warming up sounding better than ever..
when the rain stops its running in time :wave: :beer:
and just while i was in the cave touched the starter on Dori and boom fired up first time :thumbup:
MacV2 wrote: Wed Apr 10, 2024 4:53 pm Did a few bits on Rothburg.
Raided Franks stock pile & fitted a hugger.
Removed the lowered foot pegs & fitted some std ones.
Removed the gash blue bar grips replaced with some from stock.
Took the mahosive plate off & fitted a wee one, can get to the seat lock now. Was going to fit a bracket for the plate but found the undertray has been glued on with lashings of silicone . So that's a no go...Bah.
Took the fairings off to find the sidelight wire as it wasn't plugged in. Sorted that & had a mare getting the fairing to line up. Its a Chinees aftermarket job I had to enlarge the holes so I could use the correct shouldered bolts but the top right side bolt would not line up. Dug out a bracket from an F2 as they are steel not the ali as per the early bikes, bit of a tweak & it lined up.
Of course it started spitting so that will do for the day.
You've been busy Mac :thumbup: :thumbup:
fabiostar wrote: Wed Apr 10, 2024 8:44 pm
That's all sounding positive Rob :thumbup: :thumbup:
Well done Macster & Rob
yellabell
Post by yellabell »
Had a bit of a 'touch' today & not something I'd expected to go as well as it did! I'd been plus-gassing these for about 3 days. With slight trepidation, I thought "ah sod it!" and applied a fat handful of uggaduggas to my 6 point hex socket... & out they came! I'm gonna buy a lotto ticket!
Just need a split stainless flange from Macster now
ItsaKeeper
Post by ItsaKeeper »
Great job - I did the same a while back, a repeated blast of plusgas over a week, also cut a sponge into a small cube, popped in a wee bag and gaffer taped to the studs, worked a treat :thumbup:
To remove I gently tightened the studs a bit then backed off...must say it was a relief as I had read some horror stories about the drama if the studs break :sad2
Those studs can be the devils own nightmare, dont ask how i know :lol: .
once a year i wind mine out a bit to keep the threads clear :clap: two mins work to save a major sore head :thumbup:
I know I've said it before, but I'm going to say it again :lol: Plusgas is one of the best for penetrating seized threads.
Well done Mick :clap: :clap:
sirch345 wrote: Thu Apr 11, 2024 9:31 pm I know I've said it before, but I'm going to say it again :lol: Plusgas is one of the best for penetrating seized threads.
Agree but a 50-50 mix of ATF & Acetone works wonders. I mixed up a ltrs worth, in a bottle*. Shake it up, it separate's out when left, & use a brush to apply...
* Acetone will eat plastics so a glass bottle is safe for storage.
yellabell
Post by yellabell »
Ayup Mac - see WhatsApp message :wink:
yellabell wrote: Fri Apr 12, 2024 8:40 am Ayup Mac - see WhatsApp message :wink:
Sent reply...
Took Rothburg out for a spin.
Much better with std pegs on it, feet naturally find the pegs first time, gear change is spot on (bar one missed gear but new boots so that's my excuse)
:lol:
Still need to sort a few bits out. Throttle adjustment, some wiring issues & other bits...Like the cack indis !
Tucked away as start a new shift on the morrow...
MacV2 wrote: Fri Apr 12, 2024 5:40 am
Agree but a 50-50 mix of ATF & Acetone works wonders. I mixed up a ltrs worth, in a bottle*. Shake it up, it separate's out when left, & use a brush to :thumbup: apply...
Cheers Mac that’s handy to know, thanks for the reminder about acetone and plastic not getting on :thumbup: :thumbup:
I have fitted a Renthal handlebar brace, see link below if you want to see what it looks like:
https://vtr1000.org/phpBB3/viewtopic.ph ... 77#p506977
