Page 163 of 1503
Posted: Sun Jul 08, 2012 10:42 am
by Kev L
Expect a run on plastic on the commodities market on Monday "forget about Gold, Copper, Titanium, throw the big money on VTR airboxes. They are selling like hot cakes!"
Posted: Sun Jul 08, 2012 10:45 am
by tony.mon
seb421 wrote:lloydiecbr wrote:Not got that far yet :-(
I need to get some crank case breather filter x4 and some hose pipe and clips
They will have to wait till next weekend as funds are low till then .
And I need to get one more air box to cut up .-)
three air boxes?
I've got the spare I've had for a while and plan to do this mod before i get it on the dyno and set up
i would like to squeeze as much power for little money as i can outta this for now
To make the spacer with. Doesn't matter if you cut up a lid or a box.
You end up with the original airbox to sell on to recoup some money.
Posted: Sun Jul 08, 2012 10:54 am
by seb421
tony.mon wrote:seb421 wrote:lloydiecbr wrote:Not got that far yet :-(
three air boxes?
Ah yehhhh i forgot about that and the increased volume that comes with it
Posted: Sun Jul 08, 2012 11:10 am
by lloydie
[/quote]
i would like to squeeze as much power for little money as i can outta this for now[/quote]
That's my aim .
After the air box mod I will only have the ignition advance left to do .
Then that will be all the cheep mods done .
If I want any more power I will have to spend lots of money on pistons and cams and a younger engine to put them in
Posted: Sun Jul 08, 2012 11:28 am
by seb421
That's my aim .
If I want any more power I will have to spend lots of money on pistons and cams and a younger engine to put them in[/quote]
I fancied that +4 advancer for years and the shift star too
Posted: Sun Jul 08, 2012 11:42 am
by Kev L
Benny posted a while ago that he may be laying hands on some Ignition advancers which resemble very closely the Factory Pro ones. Not heard anything for a while now.
Posted: Sun Jul 08, 2012 11:52 am
by VTRDark
I was considering this but according to Mik, Mr Ditchfield says it's not worth it.
I think if one has a high comp engine with new cams then it's worth the extra as you will need a bigger oil cooler anyway, as one of the side effects of the advancer is a hotter running engine.
The money for an advancer from the states IMO would probably be better off being put towards a flow commander.
by lloydie
Kev L wrote:Benny posted a while ago that he may be laying hands on some Ignition advancers which resemble very closely the Factory Pro ones. Not heard anything for a while now.
I did read that and have been waiting with anticipation . Come on benny :-)
Posted: Sun Jul 08, 2012 11:54 am
by lloydie
Oh and I forgot about the f/c .
And the vacuum relief valve
Posted: Sun Jul 08, 2012 11:56 am
by seb421
lloydiecbr wrote:Oh and I forgot about the f/c .
vacuum relief valve,
Is that for when your bell ends stuck fast in the Dyson lol
Posted: Sun Jul 08, 2012 12:02 pm
by VTRDark
What's the vacuum relief valve?
Posted: Sun Jul 08, 2012 12:05 pm
by lloydie
One needs to be serviced every now and again but I wouldn't recommend a cyclone
Job . I like the suck squeeze bang blow
Available at most corner shops :-)
Posted: Sun Jul 08, 2012 12:06 pm
by lloydie
that's one for the mon or benny to answer
Posted: Sun Jul 08, 2012 6:57 pm
by tony.mon
Two possibilities:
1. You can fit a valve which lowers air pressure inside the engine, and seal the engine breathers. That reduces pumping friction and losses as the engine turns over piston strokes.
2. You can also fit an air bleed valve to allow some air to flow into the inlet tract when the throttle is closed. This reduces the engine braking going into corners- a track advantage mostly, as it reduces the chances of locking the rear under compression on downshifts while leant over. A side effect is that it will make the engine easier (slightly) to bump start.
Nether has been evidenced as yet with before and after dyno figures, as far as I know.
Posted: Mon Jul 09, 2012 11:18 am
by tankslappa
tony.mon wrote: A side effect is that it will make the engine easier (slightly) to bump start.
Bump starting a 'storm... Now that would be a unique video on Youtube!
It was bad enough trying to do my brother CBR900RRRRR 'blade, and usually involved me having to switch from pushing to throwing myself across the pillion seat to just get traction. I don't even want to think what would be required with the 'storm!
