The pads I took off had as much left on them as the brembo has new! I almost put them back on and thought.... sod it I've got this far now might as well throw the new ones on.
I have SBS carbons for the rear, My justification is I was not prepared to spend the guts of £35 for rear brembo's when I hardly ever use the rear brake, when I do use the rear its mainly for slow riding through town. The SBS I have heard good things about but brembo had to go on the front. Will get out in a day or so to give them a good run in up and down the road.
Luckily enough only had about 1.5 miles to ride. And no I didn't set fire to the tyre. The pipe was hanging in front of it.Bloody hell, Carl, I'm surprised you didn't set fire to the front tyre!
What is H&S Kevyou will realise H&S isn't a strong suit!
Well done Pinky.
But the are harder wearing so last a long time.Bit shy of pad tho to start with tho....
Today I fitted CBR600 Stick coils to my bike. What a noticeable difference. Bike runs so much smoother and feels more responsive.
- cliveyandrews
- Contact:
I fancy the stick coils on mine too!
Sent from my iPhone using Tapatalk and my fat thumbs...
Audi, Vide, Tace
Audi, Vide, Tace
Temp stuff, mate, 7.5 ton lorry driving mostly, but last week and for the next two I'm working for a friend decorating and doing up a house he's bought to get it ready as a student let.AMCQ46 wrote:Tony, Is this good news, you sorted out a new job now?tony.mon wrote:tomorrow.
But I'll be at work then, so perhaps I'd best do it today......
It pays much the same as the lorry driving, but with a 9AM start instead of the 4 or 5 AM start, so is preferable....
Today I took my bike around Ledbury, Marsden and Gloucester, then put in a friends garage while I go and get married in Germany. Don't worry i will be back in a week. I'm talking to the bike!!
Kind Regards
Carl Roberts
Carl Roberts
Kind Regards
Carl Roberts
Carl Roberts
You got married twice then.
Congratulations
Congratulations
http://bit.ly/R0WiSS
Just took mine out the bin lol
Finally got the Ultraseal so put some in punctured rear and brand new front.
Wasn't happy with the rear brake so removed it again and checked the slides. Looked fine, but a bit of grease and it was perfect after putting it back together.
Went out early for a quick 150 mile test early morning just to check everything was ok
Rear tyre was 2psi up when I got back so ultraseal has worked perfectly. Rear brake fine (EBC pads) and Goldfren sintered pads up front are brilliant compared to OEM even though they are hardly bedded in yet.
Doubt they will last anywhere near as long but they aren't expensive.
Bike running and feeling great and got quite a bit of attention when I stopped of at MacD's for a Cappuccino. Proof that Yellow is fastest and the best looking
'02 VTR1000-FY Yellow.
postie brought my led rear light (cheers bsm)
fitted and working within half hour! had a couple of hours blat out
dont recon my rear tyre's gonna last long in this heat!!
Took it for a MOT and it failed, Spent all week cleaning it and making sure everything was ok and it failed!
wasnt enough meet left on the front pads, has to be more than 1.5mm or its a fail, and i was the last mot of the day before he shut shop.
oh well got home fitted new pads that had turned up in post late go back next week Doh
How do they work that out then. I always thought it went by the braking force on the machine. Brembo pads have a lot lees meat on them them than say EBC's but the the compounds they use are a lot more harder wearing. So that seams a bit unfair to me. They could have given you an advisory on that, what pain.wasnt enough meet left on the front pads, has to be more than 1.5mm or its a fail
agree when i put brembos i thought my god these look like an MOT fail from the start!cybercarl wrote:How do they work that out then. I always thought it went by the braking force on the machine. Brembo pads have a lot lees meat on them them than say EBC's but the the compounds they use are a lot more harder wearing. So that seams a bit unfair to me. They could have given you an advisory on that, what pain.wasnt enough meet left on the front pads, has to be more than 1.5mm or its a fail
Reason for refusal of test certificate
001 Front brake pad (s) less than 1.5 mm thick [3.2.A1F(i)]
thats quoted off my fail sheet
Agreed here too. The brembo's seem to have no meat on them. Let my MOT guy tell me they are nearing the limit when I go next month and I'll ride the bike up his butt. The pads were new in last week!seb421 wrote:agree when i put brembos i thought my god these look like an MOT fail from the start!cybercarl wrote:How do they work that out then. I always thought it went by the braking force on the machine. Brembo pads have a lot lees meat on them them than say EBC's but the the compounds they use are a lot more harder wearing. So that seams a bit unfair to me. They could have given you an advisory on that, what pain.wasnt enough meet left on the front pads, has to be more than 1.5mm or its a fail
So today, after getting my advisory last september
1. Didnt have a socket big enough for the back wheel bolt. Ended up in Hallfrauds getting a giant spanner.
2. Brake disk would not be persuaded to come off. Solution was shedloads of WD40, a few cloths on the ground and an impact driver. It took enough twatting to make a a twatted tw@ take note! Eventually with several applications of WD40 and abuse with the driver the allen bolts gave in.
3. Master cylinder for the rear brake wouldnt play ball. More accurately one of the screws refused to give and ended up rounding. Solution: Syringe and a screwdriver. The screwdriver prised the opened side up enough to syringe the brake fluid into the res so I could bleed the brakes.
4: one of the pads went on wrong, the inside one, I did not realise at the time and was moving the bike and I heard the grind of pads on metal and had no stopping power. Hmmm I thought. Took the caliper off. Found out the problem and fixed it. No need to bleed the brake again as it turned out and I now have stopping power with the rear brake.
Hopefully thats one thing I wont fail on MOT next month.
I'd like to say thanks to Jazzscot for supplying me the brake disk, it is in better condition than my old one, which is now dumped. To anyone else in the Portsmouth area, If you need your brakes done I now have all the tools to change them including paddock stand, bleeding hoses and brake fluid and I am getting a dab hand at bleeding the buggers!
