rode the mt350 all over the place very comfy and laid back pace
did some shopping with her the guncase and panniers came in handy
east london/essex [leyton ]
- Pantaloonie
Just been out for my first ride with my new, non leaking forks fitted. It's nice not having fork oil dripping from my brake discs.
But the biggest improvement has come from the heavier fork oil and the Wirth progressive springs - thanks Benny for the recommendation
- makes a huge difference, it feels like a different, better, bike.
Roll on summer!
And I'm loving the new seat. Leather smells good...
Roll on summer!
Fitted -45mm dogbones to the wifes (my) bandit, dropped the forks nearly 20mm and ripped the stuffing out of the seat. She actually fits on it now
- BigVeeGrin
ordered new front brake light switch and cleaned seat and tank due to some ridiculously larged arsed dove/pigeon who shat all over it
- benny hedges
you're welcomePantaloonie wrote: But the biggest improvement has come from the heavier fork oil and the Wirth progressive springs - thanks Benny for the recommendation- makes a huge difference, it feels like a different, better, bike.
also very happy with the yacugar progressive rear spring from ftr suspension.... might be something else to add to your list. 80 notes but money well spent.
today i fixed a customer's media blast machine and took the liberty of testing it for him
the exhaust is to be sprayed later in firwood stove enamel, same as the exhaustively tested (
i bought a new chain & sprocket set last summer as it was 1/2 price at £45 but decided to stick with this one as there's easy 5-10k left on it. just the carrier needed cleaning up cos it was minging!
also cleaned up the footplates off my scooter - the media i used gives an excellent satin finish... i might leave them like that.
yesterday i fitted a new 21mm slide carb to it as it wouldn't idle properly with the 26mm one i tried.
this one is spot on
[youtube][/youtube]
list of mods so far....
100cc big bore kit
ported & gas flowed 19/21mm big valve head
uprated oil pump
oversize header
home made stubby carbon can
+20 degree advance race cdi
30,000v coil
iridium plug
5g rollers
21mm carb with manual choke
race camshaft
+10% gear up set
k&n air filter
lightened clutch bell
abs caliper
firestorm battery!
h4 headlight
clear indicators & tail lamp
twin horns
merc glacier white paintjob
not decided on decals yet - & still waiting on the race variator set from china, uprated clutch springs, new throttle cable & kevlar drive belt.
still to fit - camozzi twin steering damper
but so far it fkin pwns lol
- marlbororman
got it to this stage
Just need to pick oil and filter up when i finish work tomorrow, then will do the change, and fit the lowers which are all black too, then go for a ride
whats a slide carb is that the same as a cv carb?
thats how mine looked when i got itmarlbororman wrote:got it to this stage
Just need to pick oil and filter up when i finish work tomorrow, then will do the change, and fit the lowers which are all black too, then go for a ride![]()
Hmm I must pay more attention, I was reading this and continued to read into the next post!!
got it to this stagebenny hedges wrote: list of mods so far....
100cc big bore kit
uprated oil pump
oversize header
30,000v coil
iridium plug
5g rollers
race camshaft
+10% gear up set
k&n air filter
abs caliper
firestorm battery!
h4 headlight
twin horns
still to fit - camozzi twin steering damper![]()
It's only easy if you know the answer!
- benny hedges
no... a cv carb, the slide is operated by vacuum, whereas a slide carb is cable operated, it moves a piston up a bore to open the throttleDarknomad wrote:whats a slide carb is that the same as a cv carb?
a scooter cv carb (similar in ways to the storm carb) http://battlescooter.com/1.html
a round slide carb http://www.motorcyclecarbs.com/About_Mi ... s_W143.cfm
much easier to tune & set up than cv carbs imo... very simple operation & maintenance, no moving parts apart from the float, needle valve and slide.
you can get flat slide carbs too - very popular i racing, again cos of ease of setup and the larger airflow over round slides.
hth!
& yes i would like to try some fat flat slide carbs on the storm, if i could find some downdraught ones....
wonder what they'd go like with a set of big webers on!
- marlbororman
Well i got oil filter fitted got oil in, and re fitted lowers.... Then took it for a blast..............IT WAS A BLAST
- marlbororman
Timbo wrote:That looks really nice MM, nice and subtle till you get to the wheelsLike the look.
wheels are florescent orange
Not quite what I did to my bike but what I did whilst out on my bike...
My Cricket club were playing the Colchester Garrison club (not many soldiers as they are all abroad) anyhow my club have only 10 men and I only turn up to watch (man flu) chasing 136 to win we were 120odd and needed an eleventh batsman - out I go in full leathers, boots, pads, helmet, gloves and bat - I survived a 2 close run-outs and an lbw decision (and assorted sledging) only to run out my partner to lose the match.
synced the carbs today this is the best i could get them
http://s550.photobucket.com/albums/ii40 ... rbsynk.mp4
- benny hedges
ive got that same kit mike - they work really well
