New airbox snorkel mod
Re: New airbox snorkel mod
They don't fly far without them....
Maybe a dimpled bike might be a good mod
Seriously, gas flowing is often better when left slightly rough, especially nearer the transition of surfaces or edges.
But mirror polish does look much, much better.....![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
![Cool :cool2](./images/smilies/cool.gif)
- benny hedges
apparently the reason for that is the air moves faster over a mirrored surface than the fuel so it upsets the atomistion of the fuel/air mix.tony.mon wrote: Seriously, gas flowing is often better when left slightly rough, especially nearer the transition of surfaces or edges.
the way to go is smooth it out then sandblast the port for a uniform surface
mirror polish on the exhaust ports though ;)
tony,
Are you still having fuelling problems, is she still running lean. I was chatting to my old man about it and said you were getting these problems. Whilst working on old Webber carbs on rally cross cars he said it may not be that you don’t have enough fuel, because you have open the air box up to allow more air in you are not pulling enough fuel in, the only way to do this would be to restrict the trumpets slightly to increase the air flow velocity into the carbs and thus pull more fuel in with it.
or again, restrict the main air jets.....
http://www.netrider.net.au/forums/showt ... 55KxMVCgqM
this is how to get the thing to work with no lid, note the disclaimer suggesting not to remove the snorkel. id imagine it is the same deal with messing about with it. infact, this is the 2nd place ive seen which says not to mess with the snorkel:
http://www.ablett.jp/bikes/vtr/air_box_lid.htm
heres the first one i came across that stated not to mess with the snorkel
http://www.burniemorgan.com/firestorm/airfilter.html
in fact, these guys seem to have a lot covered:
http://ozfirestorm.proboards.com/index. ... hread=9754
