Carb Strip Jetting Pictures
Re: Carb Strip Jetting Pictures
Kev L wrote:Somewhere in Solihull a displaced Scotsman just had a little accident in his jockstrap. Al is the forums stopper mod campaigner :lol: :lol:
:lol: that's 2 more converts this week, just got to go and work on a few more newbies, before the get their heads by those peddling the fancy anodised manuals :lol:
scott02464 wrote:
AMCQ46 wrote:Scott, good work on te carbs, but if you havnt put stoppers in your CCTs, thats your next job :thumbup:
Thanks mate, yes I put the stoppers in a while ago. I had already bought new autos so thought I'd do the stopper rather then spend more on manuals ;-)
:thumbup: good thinking, not that I am biased :lol:
Re: Carb Pictures
cybercarl wrote:Thank you very much Hawk Nice to have that confirmed, most appreciated. I did try the fatory pro approach and I'm not sure it made that much difference. Plugging 1 hole in each slide I will try next, I am running two long stacks. I'm hoping plugging a hole will also slow the slides down a bit and stop them coming on so soon.
Ride safe buddy. :thumbup:
Plugging a lift hole is normally done with the short stack and aftermarket stacks as those are the ones that get the slides bouncing and\or opening too quickly.
I normally run the stock 2 lift holes with the long stacks but I haven't had a lot of experence running to 2 long set up, so it is worth a try to see how if works.
mavar1ck
Post by mavar1ck »
Stripped my carbs down to clean out now putting them back together and noticed a 1 stamped into one carb cap and a 2 stamped in the other. Are the carbs numbered 1 and 2? Just want to check they are on the right ones as there were some washers missing from work by previous owner when he dynojetted it.
When you say cap I presume you mean the Plastic diaphragm cap on the sides. I can't say I have seen any numbers stamped on them before, and it should not matter which one goes on which carb as they are identical as far as know.
With regards to washers/shims you should have two. One under the needle and one on top under the spring.
http://www.lingshondaparts.com/honda_mo ... ck_03=6100
scott02464
Post by scott02464 »
Carl if I jack up the needles with a packer washer (instead of buying an adjustable needle) is it the bottom or top washer I 'pack'?
If you are going to shim the original needles you can only put them underneath which raises the needle to richen.
I'm not sure how this will work if you put larger mains in and run the K&N filter.
http://www.superhawkforum.com/forums/te ... -up-24769/
scott02464
cybercarl wrote:If you are going to shim the original needles you can only put them underneath which raises the needle to richen.
No worries, just a thought mate ;-)
Where is the popcorn eating icon.... :lol: Looks like my little set up thread is alive and well over here. :wave:
As for the diaphragm caps, if that is the part you were talking about, I have never seen them numbered either.
As you post on the right hand side :Beer Popcorn: sitting right above view more smilies. :wink:
:lol:
8541hawk
when a dyno jet kit is fitted and the extra hole is drilled in the slide as mine is would it be best to plug it ?
I also have billet stacks and a modded airbox and a 2-1 exhaust .
lloydiecbr wrote:8541hawk
Too small to see properly, can you make it bigger, and with more horsepower and torques?
I did think about this for Lloydie this morning.
Love that kick at 10,0000 where it suddenly develops 30bhp more. That must be a handful in the wet......
It's still running very rich after 4K, though.
Mains?
