Page 3 of 4
Re: Finally got the JE High Compression pistons put in
Posted: Sat Nov 21, 2015 4:12 pm
by tony.mon
Sir-knob-head wrote:Who did yours tony.mon?
Newman Cams.
Not really recommended though, as I had to chase a lot to get them done.
Luckily they're local to me, I pass them on my way to work each day, so was able to make a nuisance of myself and get them done, but it still took weeks longer than promised.
It's all in my thread about getting these done- I know there's a lot of stuff on here, just use search to find it.
In my experience, high comps on their own work well, it's not cheap but gives good results, especially with a free flowing air filter and cans or a full system.
Posted: Sat Nov 21, 2015 5:32 pm
by darkember
8541Hawk wrote:I guess I need to add more qualifiers to my posts for you guys......
Yes of course you will get gains in the top end when you up the compression ratio.
You should have power gains everywhere, though if you want the engine to breath at the top of the rev range with higher compression, you need to change the cams.
If you are not going for top end, then the stock cams should work pretty good for you though you might need to play with the timing a bit for max power.
Or just go for exhaust cams all round :thumbup:
Posted: Sat Nov 21, 2015 6:22 pm
by tony.mon
Sadly that makes no noticeable or measurable difference.
The lobe height difference is point something of a mm, which helps a little, perhaps, but as I said, isn't measurable. I think that its more of a psychological boost, a placebo effect.
Sorry, but done many swaps, no boost.
But I will have a pair of 2nd hand std bore JE high comps for sale in the very near future....
Posted: Sat Nov 21, 2015 10:11 pm
by darkember
Ton are those the ones with holes in :lol: :lol:
Posted: Sat Nov 21, 2015 10:14 pm
by tony.mon
Very droll!
These are the ones I bought as a replacement for the ones with holes in.
Posted: Sun Nov 22, 2015 6:56 am
by Stephan
IN valve lift 10.3, EX 10.15
Ex cam swap doesn't help at all.
Posted: Sun Nov 22, 2015 8:31 am
by NZSpokes
General question. Is there any use in skimming the heads to lift compression? Keeping the stock bottom end?
Ive not had one of these apart so not sure of the head area etc.
Posted: Sun Nov 22, 2015 9:05 am
by lloydie
NZSpokes wrote:General question. Is there any use in skimming the heads to lift compression? Keeping the stock bottom end?
From what I've read you can skim the heads ,
Unless it's done with other mods ,like Pistons ,cams , porting, and full exhaust it's not worth it .
You'd be better off $$ selling up and getting a busa !!
I didn't skim my heads when I build my engine tho I might on the next one .
Posted: Sun Nov 22, 2015 11:47 am
by Stephan
I would do it if I don“t have hc pistons, have some calculations for it (how much .x mm is for CR ...), but keep in mind you have to readjust timing of cams (on cam sprockets), and you will be able to go somewhere to 10.5 max.
Posted: Sun Nov 22, 2015 5:40 pm
by NZSpokes
Was more wondering out loud. Would only bother if i needed to have the heads off.
Busa's are to common. And nowhere here you can really open one up.
Posted: Sun Nov 22, 2015 6:36 pm
by lloydie
There common here to tbh but like the bird you don't need to rev the crap out of them to make silly fast progress .
Really looking forward to getting the track bike finished just so I can ride a twin again .
Posted: Mon Nov 23, 2015 5:19 pm
by Sir-knob-head
lloydie wrote:There common here to tbh but like the bird you don't need to rev the crap out of them to make silly fast progress .
What's your track bike lloydie? Don't tell me. Stormer?...
Posted: Mon Nov 23, 2015 6:02 pm
by lloydie
Yep a storm
If I ever finish it
Posted: Mon Nov 23, 2015 6:27 pm
by Sir-knob-head
Good stuff.
You're almost there right?
Posted: Mon Nov 23, 2015 6:37 pm
by lloydie
No lol months off tbh .
Lots to do ,just can't be arsed
