The stock spring rate is .585 kg/mm and as you say way too soft and not linear.NZSpokes wrote:Im on .95 and im 102kg. Stock is .56 from memory. Way to soft.
Front Fork Advice Needed
- thunderbolt
Re: Front Fork Advice Needed
Don
Bikes:
1981 Moto Guzzi 850 T4
1990 Suzuki VX800
2003 Honda Firestorm VTR1000
Don
Bikes:
1990 Suzuki VX800
- thunderbolt
I am 12.5st and when kitted up am probably a bit over the 13st mark but these springs seemed to work ok with me on board, but maybe the preload was wound in a bit to compensate.sirch345 wrote:I'm using 0.85 fork springs, I weigh just over 13st (80.5kgs) kitted up and that suits me fine.thunderbolt wrote:PLEASE EXPLAIN !!! (to quote one of our politicians).NZSpokes wrote:Thats a .85 spring.
.85 kg, .85$, .85?
Thanks NZ
Don
Bikes:
1990 Suzuki VX800
Don
Bikes:
1990 Suzuki VX800
I weight roughly 72-80 kg (11.5 st) and was recommended 0.85kg/mm linear springs measuring in total including spacer 410mm. If a spring is longer or shorter than this then adjust the spacer accordingly. This is which is what I used in the Fork Service Guide along with 7.5w oil and an air gap of 140mm.
I would say that .95 is about perfect for your weight. Don't forget to include full riding gear in with that weight.I am 12.5st and when kitted up am probably a bit over the 13st mark but these springs seemed to work ok with me on board, but maybe the preload was wound in a bit to compensate.
- thunderbolt
ok thanks
Don
Bikes:
1990 Suzuki VX800
Don
Bikes:
1990 Suzuki VX800
- thunderbolt
Carl,
Thanks for those suspension articles you sent me. I found them very informative and interesting to read.
They were very much appreciated.
Don
Bikes:
1990 Suzuki VX800
Don
Bikes:
1990 Suzuki VX800
