tech info ?
EmilyJaneNA
Re: tech info ?
Post by EmilyJaneNA »
Since I got the bike I've noticed the gearbox lashes under 3000 rpm in 1st 2nd and 3rd ...is that normal for a twin or am I up for spending a fortune :/
Re: tech info ?
can you explain the term lashes?
the storms gearbox can be very clunky between 1st and 2nd, but after that it's fairly smooth, the more you ride it the more you get used to it and you'll learn to make smooth gear changes, just a thought, is your chain properly adjusted, this will effect gear changes of course.
and not wanting to be a keyboard Nazi, if you post this question in the workshop section, you'll get a better response..... :thumbup:
Re: tech info ?
I too was wondering what exactly you mean by lashes, if you mean the transmission is slack it could be worn cush driver rubbers. They fit behind the rear sprocket carrier, you can check if they are badly worn by seeing if the sprocket with it's carrier will move back and forth without the rear wheel moving.
I agree with A/P, better of putting your question in The Workshop section,
EmilyJaneNA
Re: tech info ?
ehhh........~sighs~ bike broken again ,starter transfer cog, and the starter motor making a weird noise ive never heard before ....its just gonna have to sit in the shed till I get time off work to look at it :cry:
Re: tech info ?
Did the sprag clutch rollers get checked when you was last in there? Is the bike turning over as in cranking or does it sound more like the starter spinning without cranking the engine over. Starter bushes possibly :think: It would be a good idea to strip, check and clean the starter as these are a common failure area, especially the bolt at the front where the live cable attaches.
http://www.vtr1000.org/phpBB3/viewtopic.php?f=9&t=26048
Where about's in Oz are you, there may be a member near you that could lend a hand. We have a few members over there.
Re: tech info ?
sorry to hear of the bike woes but welcome along to the madhouse :D
EmilyJaneNA
Re: tech info ?
:D bikes purring like a lion ! , spent the past 2 days trying to get it all fixed and.......had a friend tig the starter cog up , and he fixed the fuel tap vacuum thingy while I was at work , Awesomeness !!!! :D . was wondering tho ...if I were to re-paint it what colour should I go with .... ? pearl black , red ,or purple ......... ? :3
Re: tech info ?
pearl white with red graphics would look real good........ :thumbup:
Re: tech info ?
EmilyJaneNA wrote::D bikes purring like a lion ! , spent the past 2 days trying to get it all fixed and.......had a friend tig the starter cog up , and he fixed the fuel tap vacuum thingy while I was at work , Awesomeness !!!! :D . was wondering tho ...if I were to re-paint it what colour should I go with .... ? pearl black , red ,or purple ......... ? :3
Glad to hear you've got your bike fixed :thumbup:
Colour is a personal thing really, it's what you like. I like Red, but isn't that what you already have now :?: going by your avatar picture. As A/P suggests, white does look good IMHO,
Re: tech info ?
Good news on getting the bike up and running again. :clap: :clap: Get some pics up so we can have a closer inspection. :thumbup:
