cybercarl wrote:I did have some great links bookmarked regarding research into this but can't seem to find them.
Intake reversion or reversion in carbs is what you want to be looking up. I believe it is basically to do with the valve overlap period and scavenging....
Was going to banter on about something along these lines until I read this post. Suppose most of it has already been said.
But to put a spin on it, what is a carb fart? Well it's a fart almost like any other. Trapped gas finding the easiest route to escape. It's highly unlikely (imo) that atmospheric pressure has a part to play. After all, gas being collected and stored somewhere in between two warming cylinders will increase in pressure anyway, whether you're above 1 bar or below!
But think about it this way, you have two cylinders working in the four stroke system. Large cylinders that vary in total volume during each cycle due to the reciprocating mass (piston mainly in this instance) in motion. There's only a combustion every second approach to TDC (still unsure of the storms timing shamefully), for example spark at 13* BEFORE TDC. Before this ignition, the inlet valve opens just as the exhaust closes and draws fuel and air mix in, the fuel naturally ways more than the air and as we're talking carbs, not very well vaporised upon introduction.
These larger fuel particles can contribute to something significant (as a theory of the top of my head!);
Sink towards the piston faster and become unspent fuel until the exhaust/ next in-take stroke. At this point, any fuel left in the cylinder can become burnt off due to the temperature as well as altering the pressure in the cylinder upon in-take stroke and as the fuel has a greater mass, it's the air that has to be left out (linked to running rich/ lean in a way in that sense). Once the valve is closed, the system is now closed but there is still air in the system that needs to escape. For this air which has suffered friction by being sucked in to the cylinder near the speed of sound and then forced back out is now warm and by it's very nature travels upwards. This warm air then gets trapped until enough is gathered to increases enough pressure to push back on the carbs slide springs, up past the velocity stack and pops in your air box as a form of relief (a sudden increase in volume to fill).
Hope that makes some form of sense... As a theory!
I've found neither running rich or lean, standard cans or straight throughs makes no difference to the potential for carb fart. I've run lean but currently run rich. Yeah rich uses more fuel and requires more frequent plug changes but the bike feels nicer for it. Plus, I never ever suffer heating issues. What else I have found is that as it takes longer to reach mid-way on temp scale, I also suffer less puffs than I used to. This could be related but it may not... However, keeping the temperature cooler, especially the rear by running rich, there could be less chance to produce increases in cylinder pressure through unspent fuel.
I like theories
I'm not death to power tools... If it breaks, it's obviously NOT a power tool!!!
