Handlebar conversions
- Contact:
Re: Handlebar conversions
Measured just now, but it is dark in garage and I'm not sure I got this right but I have them at 760 and 920
But I am knackered so that's my excuse
Will maybe take them off to measure ( they need to come off anyhoooo)
- Contact:
The left one does go down and then off at 90 degree angle
- Contact:
I'm thinking that master cylinders like this might mean less fairing cutting
https://www.ebay.co.uk/ulk/itm/351358903151
I'm a little nervous about stuff imported from China, ( some of it is meant to be good, but brakes?)
but does anyone know of a UK supplier, or if I can get similar from a different bike?
- Contact:
It's finding a matching lower profile clutch master cylinder that is proving problematic
I am drawn to those Chinese ones listed as they look the part......but so did the Titanic!
- Miztaziggy
Personally I wouldn't worry about it being Chinese, but if you are worried, then there must be plenty of bikes out there with a clutch cylinder like the one you're after?lockwood1956 wrote:It's finding a matching lower profile clutch master cylinder that is proving problematic
Cbr 600 has that type of master, but is a different piston diameter so will effect your brake feel.
But if you get both master and calipers then you also get improved braking performance ... See this thread http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=15494
- Contact:
That's great info
Thank you for taking the time to post and for the help
Bob
Bob
I never bothered to change the clutch master cyl as it sits inside the fairing and has no effect on how much you need to cut off to clear the bars.
Have a look at these photos
http://www.vtr1000.org/phpBB3/viewtopic ... 45#p240524
As above. the clutch side is ok for clearance , its the brake side, when i had the high bars on mine i used the standard storm master but changed the big standard reservoir for a mini motox one and it fitted fine.
- Contact:
Thanks again for the info and assistance
CBR 600 master cylinder on its way to me as we type.
Are the calipers a straight swap?
calipers need a little bit of machining to clear the fork leg lugs .... or the fork leg lugs need a bit of machining to clear the calipers..... or do what i did and take a bit off both!
- Contact:
Hi Chaps
Fitting braided hoses, what size double banjo bolt do I need for the master cylinder.....
is it M10 X 1.0 or M10 X 1.25
thanks in advance
thanks in advance
- Contact:
CBR600 Calipers arrived....they look quite a bit smaller than the standard ones, will look a bit closer at the weekend
http://www.ebay.co.uk/itm/161993723548? ... EBIDX%3AIT
lockwood1956 wrote:CBR600 Calipers arrived....they look quite a bit smaller than the standard ones, will look a bit closer at the weekend
they are off the wrong model......... too early.
needs to be
Honda CBR 600 FX/FY/F1/F2/F3/FS1/FS2/RR3/RR4 models fitted with 2x 34mm and 2x 32mm piston
1999 to 2004
