Page 236 of 1530
Posted: Fri Dec 21, 2012 7:38 pm
by VTRDark
Have you still got that ticking coming from your engine ? .
Please tell me you have done the stop mod. Just in case, better safe than sorry.
Posted: Fri Dec 21, 2012 9:46 pm
by mr.john.coates
lloydiecbr wrote:mr.john.coates wrote:Took it out the shed...rode it around North Leicestershire for 80 miles...cleaned it...applied Mr. Sheene...ate mince pie...Happy
Have you still got that ticking coming from your engine ? ...
Ticking? What ticking? I don't have ticking.
Did you hear something when I was at yours ???
Worried of Loughborough
Posted: Fri Dec 21, 2012 9:50 pm
by mr.john.coates
cybercarl wrote:Have you still got that ticking coming from your engine ? .
Yes, Carl, done it. Lloydie now scaring sh1t out of me. I'm paranoid about ticking now. It that your watch? Or mine? or my engine...
Posted: Sat Dec 22, 2012 5:13 am
by lloydie
mr.john.coates wrote:lloydiecbr wrote:mr.john.coates wrote:Took it out the shed...rode it around North Leicestershire for 80 miles...cleaned it...applied Mr. Sheene...ate mince pie...Happy
Take your ear plugs out on your next ride !
I thought I mentioned it before :-( sorry
Posted: Sat Dec 22, 2012 7:43 am
by mr.john.coates
Sheeeet! Now I am worried - I'm going to take a listen today and report back. I sometimes get a 'camchain slap noise' once in a while and it might be a bit tappetty-sounding but ticking? Was it engine speed, when I took off? idling? It must have been loud cos you weren't that close!
Posted: Sat Dec 22, 2012 9:21 am
by lloydie
Engine speed and loud :-(
Posted: Sat Dec 22, 2012 10:39 am
by mr.john.coates
lloydiecbr wrote:Engine speed and loud :-(
OK, Any of you good boys out there got any thoughts?
I've done the stopper mod, she starts and runs well, no obvious faults. Sometimes (rarely) there's a 'hiccup' at tickover speed with a sound like the cam chain might be slapping...Tickover is set at about 1400 as below that it stalls sometimes.
Posted: Sat Dec 22, 2012 10:51 am
by Wicky
As the stopped mod is a stop-gap safety net in case of CCT failure - If you suspect the CCT has gone then the option is to inspect for the spring breaking and if so rinse and repeat stopper mod with a new CCT - or go the whole hog and replace with manual CCTs for complete peace of mind.
Alternatively fit louder cans so any rattling noises are drowned out
Posted: Sat Dec 22, 2012 10:58 am
by VTRDark
As for CCT's I would go manual cause Honda ones still fail and need replacing. The problem is it's hard to diagnose a sound from description over the internet. As for cutting out, that's more down to tuning. Adjust the TPS and giving the carbs a balance/sync generally sorts this out, as long as the cab jetting and mixture is all good.
Posted: Sat Dec 22, 2012 11:50 am
by lloydie
It didn't sound like ccts more like a shim but louder and slower
Posted: Sat Dec 22, 2012 3:47 pm
by VTRDark
Just popped across town for a cuppa with Marty. I did mention in another post that my jetting is not spot on as I have been playing, but my bike seems to be running to perfection. Maybe a little rich (approx 80miles before reserve) but these bikes prefer to be on the rich side. I have her running between 900 to 1000rpm at idle when at full running temp with very minimum needle fluctuations and ticking over smoothly. Mixture screws may need tweaking a tad! 2nd gear low speed is good as there is no stumbles and the torque is there to pull through corners. All in all she's running great
The funny thing is I am currently running pretty much a standard set up and have shimmed original needles. Current settings as follows:
01/12/2012
BMC (street filter)
Front carb
175 main
48 pilot
Needle clip 4th from the bottom
Standard 10though shim
A/F Done by ear
standard emulsion tube
Standard lift holes
Standard Tall Stack
Rear carb
178 main
48 pilot
Added 20thou Shim and left out the standard 10though shim
A/F Done by ear
Standard lift holes
Standard Tall Stack
I think that has got to be one of the most enjoyable rides I have had in a long time and that is in the wet. My tyres are superb, very confidence inspiring with great feedback. Steering is so much better as well. The bike just falls into the corners now
but I do need to replace my front wheel bearing very shortly, it's been on the way out for a while now and the swishing sound I'm getting is telling me to replace this. Oiling or greasing does not improve it by much
Tapered steering bearings will be next as well.
Although the bike is running great I still want to play with my spare carbs, fit FP kit in them and drill/enlarge the main air jets
Posted: Sat Dec 22, 2012 4:21 pm
by agentpineapple
started the bike up again, started first time on the button, then disconnected the battery for the xmas period, put the cover back on, had a cuppa and a chat with carlos, now of to work....
Posted: Sun Dec 23, 2012 8:05 pm
by leevtr
Rode it. Made me grin like an idiot. Was getting serious withdrawal symptoms. Needs a good wash now, job for tomorrow !!!!!!
Posted: Sun Dec 23, 2012 8:13 pm
by lloydie
I hope to get out on mine next week for a little ride . As I need a fix .
I did run it up to temp today for its weekly warm up but then put it back to bed .
Posted: Sun Dec 23, 2012 9:55 pm
by chric
