Ordered "Honda" decals -light grey, for both sides of belly pan as well as "HRC" decals. Should brake up the block of black. Griff.
Immediate plans:Clean it!
- BigVeeGrin
Sounds good.
I went to my mates where it's in his (damp) garage and was going to go out but it was pissi g down so didn't. Ran the engine for a while and gave it a good wipe over and was going to spray some ACF50 but forgot it.
Fitted the hrc tank pad and filler cap cover .
Been quite busy fitting and breaking stuff
to my bike lately so thought I'd take some photos.
Ohlins shock fitted
cbr900 front end ( has made a massive improvment over the standard forks relatively cheaply. Was a bit of fiddly modifying the HISS to fit the top yoke)
danmoto bars ( had a few problems with these not tightening up enough. Replaced each of the bolts with long m6 bolts so I could get a nut on the other end and really tighten them up and now sorted. Other than that problem the bars seem good quality)
pazzo copy levers
hugger
steering damper
I have drilled holes in the the subframe and remounted the high level cans more securly. Seems the most logical way of mounting high level cans
Next things to do are fit the braided lines I have, get the tank resprayed as the tank is faded, fit a marowaki style undertray, get spare wheels and spare subframe powder coated black and fitted.
Oh and give it a clean when I can be arsed
Ohlins shock fitted
pazzo copy levers
hugger
steering damper
I thought yours was silver !!
Good work and I to like the early blade front end . Ohlins would be nice let us know how you get on with the shock :/)
My last one was but some kids decided to borrow itlloydiecbr wrote:I thought yours was silver !!
I didn't know they replaced it .
But why a slow red one ?
Still faster than silver tho ::-):
- benny hedges
sat in all day waiting for mce to bring my bike back, as promised.
but as expected they let me down.
so i did a lot of this instead
fiddler hate it when people let ya down . :-(
New year new bike then benny
Nice work there Steve, bike should run nice with those suspension mods....we will have to have another run up the Snake Pass
Benny, I assume they have told you fiddler is good physio for your wrist
Hope the bike looks good when you get it back
Just did the led light block conversion for the tail light, had to split open the taillight housing to install the unit using hit gun and couple screws.
The new light is now much much brighter, got the unit at a local auto store for $19 and change, great mod'!
upcoming mod', the R1 R/R unit, maybe tomorrow night
You never see a motorcycle parked in front of a psychiatrists for psycho therapy. All I need is cycle therapy
It is the season for playing with the bikes giblets :-)
Keep it up !
Keep it up !
My lad Iand I went into the garage this morning at 6am as he stayed over last night .
It was him who woke me up to do some work on his pw80
We made a bracket for the end can and a bracket for the seat unit .
And fix the hole in the Lhs plastic engine case and refitted the casing .
Fixed the rear brake so that works now
We are waiting on some parts now like carb and throttle cable and throttle housing and tube .
And some blue grips .
Then it will be the test ride
just to make sure it all works before the strip down .
Got it out of the garage, took a spin down to Hein Gericke, took a couple of pics, put her away.
leevtr have you got a picture of your bike from the rear ?
if not can you take one next time you take it out as id like to see the angle of them nice cans from the rear
