Thermal paste works best when directly between two bare metal surfaces - layers of paint will impede the heat transfer efficiency you're looking for and will cause electrical resistance potentially causing earthing problems.
Diabolus wrote:
Wicky wrote:Looking good - don't forget etch primer is nasty toxic stuff and scrape some of the finish off from the subframe when remounting the R/R so it can efficiently ground/conduct heat away.
how is the rear flappy rubber thing meant to fit? the one that starts at the tank mount
It starts from the tank mount and then wraps round the fuel tap - presumably to stop any unfortunate fuel leaks landing directly onto a hot engine
As wicky said but I will add it sort off goes in a U shape, so drops down then comes back up. The two slots in the rubber go over the tank mount before sitting the tank back over it.
Those cam covers look fantastic, and that Graphite colour is not too bad.
Posted: Thu Jan 03, 2013 3:12 pm
by firestorm1997
Thanks for the feedback guys,,,,
Posted: Thu Jan 03, 2013 4:10 pm
by Wicky
Not what I did to the bike but the other way round - The side stand fractured my right little toe!
I was giving the baglux tank bag a tug when it was on the paddock stand, which caused the bike to roll off and forward and the side-stand with the weight of the bike landing on my cunningly placed pinky - Happy it stayed upright though immediately afterwards I was hopping & swearing like a one-legged kangaroo....
Posted: Thu Jan 03, 2013 4:43 pm
by Diabolus
Wicky wrote:Not what I did to the bike but the other way round - The side stand fractured my right little toe!
at least you didnt drop the bike
Posted: Thu Jan 03, 2013 5:50 pm
by VTRDark
Bled my brakes, especially the rear as that hadn't been done since fitting my rearsets. The fronts are as good as they are going to get, but I'm not that happy with the feel at the lever. I need to look at upgrading the front set up as some stage. New MC time me thinks
Hope the toe heels well Wicky. I have three toes which have heeled in the bent position which is a nightmare walking on sometimes and wearing boots. Good job you had the sidestand down or the whole bike might have landed on you.
Posted: Thu Jan 03, 2013 5:57 pm
by lloydie
Wickyrooo good save !
Broke my no2 toe last year when I fell up the stairs . It's not good hobbling everywhere for a few weeks .
And good that you saved the bike .
Posted: Thu Jan 03, 2013 6:20 pm
by AMCQ46
save the bike worry about the toe later! what more can a man do for his machine
get it strapped to the next one and wear slippers to work
Posted: Thu Jan 03, 2013 6:21 pm
by Wicky
call me 'limpy' now! Though it gets interesting in a week or so when I have an op on my left leg, so I'll be limping on both legs!
lloydiecbr wrote:Wickyrooo good save !
Anyhoo found the perfect accessory for chric, lo and behold...
[youtube][/youtube]
I can see it wagging when he cleans his bike, and wagging furiously when he's riding his bike. Combined with the furry ears he'll be in fear of the RSPCA collaring him...
Posted: Fri Jan 04, 2013 5:21 pm
by lloydie
Filled it up went for a ride around the Cotswolds filled it up again road home 250 miles in total and one of the best January rides I've been on .
Pic at a coffee stop
Two more faults found !!
Gear indicator needs reprogramming
And the clutch is slipping at high revs 7k+
So I will be getting a Barnett clutch next month and a service at the same time :-)
Posted: Fri Jan 04, 2013 6:31 pm
by AMCQ46
nice one Lloydie and here am I still at fecking work at 6.30
Posted: Fri Jan 04, 2013 6:34 pm
by lloydie
AMCQ46 wrote:nice one Lloydie and here am I still at fecking work at 6.30
at work but not doing work
Posted: Fri Jan 04, 2013 6:41 pm
by VTRDark
Little Chef, you call that coffee I'd rather drink my own piss
Electrics all good then and the bike has had a proper test run
Posted: Fri Jan 04, 2013 8:22 pm
by Virt
lloydiecbr wrote:Filled it up went for a ride around the Cotswolds filled it up again road home 250 miles in total and one of the best January rides I've been on .
I'm disappointed, didn't hear you going doing the road at all ;) Bit brave though, going 250 miles when you last had a major fault after 800 yards
Posted: Fri Jan 04, 2013 8:38 pm
by lloydie
Like I said only one way to test it "ride the butt off it "
Electrics were fine lol .
We didn't go through ya village sadly :-(
We headed down the fosse to Cirencester then Swindon - Oxford and a longer way back ;-)
