woaty
Re: what have you done to your storm today
Post by woaty »
Jazzscot wrote:Went to the garage and started her, then sat and looked at her like a saddo while she purred at me for a while. Then switched her off and gave the tank a wee wipe
Jazz
nothing wrong with that :thumbup:
Jazz
Although I would, myself, have wiped the tank with an oily rag or polish instead.
Wee is probably corrosive.
But at least it's free.....
:lol: :lol:
That's a picture of the APE slotted ones
Yep put that there to show an example. I would just do the original ones then you have the added bonus of the timing marks on there as well in case needed. :wink:
tony.mon wrote:
Jazz
and storminghonda would'ave wiped his tank with your shirt tony...... :lol: :lol: :lol:
cybercarl wrote:A nice de-coke. So what are your intentions with it, are you going to rebuild an engine out the two. Have you tried moving the crank now the heads off. You might as well do a bit of light port work while it's all off. Remove the valves, give them a clean up and lightly grind back in. If I was you I would get the cam wheels slotted as well. At least you have something to play with there then, even if it's just to compensate for any cam chain wear. You really will have your timing spot on then. :biggrin (:-})
tbh i dont know yet !
i have thought about reconditioning the heads with a light port and polish to begin with (when funds are better) as i need some tools to do it .
then strip the rest of the engine down and get the bores measured if the cases are ok that is . and have them rebored and fit nice new over size pistons (hi comps if funds are good ) then swap over the crank and gear box from kermit .
but as this will cost £500-800 it might take a wile .
or just get a low mile engine with cct failure and swap the heads .
adyf
Post by adyf »
Just got her back from my mate,he is bike mechanic,manual ccts now done thank god,exhaust cams as inlets(cheerz Benny),tps set,single throttle cable,reshimmed,iridium plugs,fresh oil and coolant,New sintered pads,New front Avon 3d supersport and sport rear,oh and pipercross airfilter.took her out sat cold but dry,bike is transformed ,smooth and grunty ,not run avons in yet but grip is awesome,what is it about vtr's? they do get under your skin,bloody thing costs me a fortune but I love it,roll on spring. Cheerz all ady f.
adyf wrote:Just got her back from my mate,he is bike mechanic,manual ccts now done thank god,exhaust cams as inlets(cheerz Benny),tps set,single throttle cable,reshimmed,iridium plugs,fresh oil and coolant,New sintered pads,New front Avon 3d supersport and sport rear,oh and pipercross airfilter.took her out sat cold but dry,bike is transformed ,smooth and grunty ,not run avons in yet but grip is awesome,what is it about vtr's? they do get under your skin,bloody thing costs me a fortune but I love it,roll on spring. Cheerz all ady f.
Did he degear the cams or just fit them as is ?
chric
Post by chric »
de stickerd some parts tightend a few nuts thats it
adyf
Post by adyf »
Hi lloydie I asked him if he maybe swapped sprockets from inlet cam to exhaust cam but he said he just dropped them in then timed em up,did say not much difference in lift he measured it out of curiosity but different duration,not made much difference,just feels like its running better somehow,ofcourse he was doing ccts anyway so easy to do cams with no chain tension.you thinking of something similar? Cheerz ady f.
adyf wrote:Hi lloydie I asked him if he maybe swapped sprockets from inlet cam to exhaust cam but he said he just dropped them in then timed em up,did say not much difference in lift he measured it out of curiosity but different duration,not made much difference,just feels like its running better somehow,ofcourse he was doing ccts anyway so easy to do cams with no chain tension.you thinking of something similar? Cheerz ady f.
Yep I picked up a set of cams of benny a few months ago with the intention of fitting the four exhaust cams but not much info out there on fitting them correctly !
adyf
Post by adyf »
Yeah know what you mean,I looked allover for info, used to be quite popular a while ago apparently,didn't trust myself to do this so gave it to a pro,I'm sure someone on here will know,if you struggle I'll pass on my mates number he's a nice guy would help if he can.cheerz ady f.
There's two ways one can go with the exhaust cams. 1: just drop them in and set up with standard timing marks. Which I suspect would be perfectly fine as the exhaust cams are not that extreme, Or 2: get a degree wheel out, work work out when the piston is exactly at TDC and set the pointer on the wheel to zero, get the cam centre lobes set up, do a bit of maths and set at whatever degree you think may work. Then see how the bike rides. It's a shame there is no info out there where someone has already done the testing and worked out what is the best degree for it.
I'm lazy and no good with maths and it's all a bit of faffing around, If I get some exhaust cams I shall just drop them in. I will slot my cam sprockets and then just move them slightly (maybe a degree at a time) After setting the crank to TDC, until I feel an improvement or not. With loads of clearance on the standard piston crown there's probably some room to play safely. After all we know a cct failure will have to be more than two teeth on the cam sprocket before it causes damage.
I'm feeling very tempted to get some and have a play around. :think:
I took off the top yoke and started cleaning it up, then ended up fileing, sanding it, wire wooling it and polising it............put it on the bike and it looked too 1980's :( , to then I sanded it rough again, primed it and started painting it with Hamerite smooth black.
Think it might be a bit cold for spray painting so stopped after 3 coats as it is not covering the edges and the red primer is still showing through!
talk about a waste of an afternoon!
That's what you call making work for yourself. :lol: :lol:
Spray Hammerite is so pissy thin it will take more than 3 coats.
Where I am current dew point temp 1.0°C and 100& Humidity
Hammerite - Minimum application temperature : 3°C above dewpoint Apply 2-3 coats, leaving each coat for approximately 1 hour or until it is touch dry before applying further.
Ideal application temperature : 8-30°C (46-86°F) coats. Maximum relative humidity : 85%
Best wait until spring Image
