That reminds me how scared I'm gonna be of declaring my rear shock...lumpyv wrote:
just wondering carl and bvg. did you fess up that you have non-standard exhausts to your kindly insurers?
like carl I did and they weren't bothered as long as they are less expensive than standard replacements from Honda - no idea how much they are mind but i reckon a pair new would be £300 pluslumpyv wrote:just wondering carl and bvg. did you fess up that you have non-standard exhausts to your kindly insurers?cybercarl wrote:I'm with Devitt but one might as well right a list of every insurance company/brokers in the book. they are all as bad as one another. Grrrrrr
or £20 on ebay....Kev L wrote:Just looked on Lings and the standard exhausts are £276 a side.
Wish I could remember my last settings mate, not got a clue what my A/F is set at. Don't know how you can happily play with it in this cold it just depressed me, it's great tho on a warm sunny day with a few coffees and the odd beer to hand I'd do it all day long but not on a dank winters day, if I had a garage I could move around in then that would be great but have to do mine at the front of the house on the road sidecybercarl wrote:Today I decided to do some carb fettling and put my FP kit back in, now I have 45 pilots. All I have got to say is WOW!!! it put a grin on my face. The front just wants to lift off the throttle and I can really feel how bad my front suspension is nowI'm sure if I changed my gearing it would wheelie off the throttle
Fork upgrade is next on my list. Going to stick with standard forks and upgrade the springs, taper the rebound rod etc.
My current setup is as follows:
BMC Street filter and Factory Pro TI Kit
Front carb
175 main
45 pilot
needle clip 3rd from the bottom
Removed standard 10though shim
A/F 2 ¾
standard emulsion tube
Rear carb
178 main
45 pilot
left the standard 10though shim in
A/F 2.5
I shall have to wait and see what my fuelling is like now, hopefully it has improved. I may have to tweak things slightly. Possibly put a rear emulsion tube in the front as well. And/or up the mains 1 size up. But on the other hand I don't want to mess with things if it's running well.Maybe I will take it for a dyno run first and see where everything is at before tinkering again.
I got lucky with the mixture and took a guess and set the screws while the carbs where off and the bike's idles perfectly at around 9000 then as the bike gets up to full running temp it idles at 1000 with no fluctuations when blipping the throttle.
I'm happy![]()
I'm happy![]()
Haha! Too easy!!tony.mon wrote:Seems a wee bit high, don't the neighbours mind?cybercarl wrote:
I'm happy![]()
For the uneducated amongst us, what pipes are you running to complete the set up?My current setup is as follows:
Front carb
175 main
45 pilot
A/F 2 ¾
Rear carb
178 main
45 pilot
A/F 2.5
