So started doing a bit of work the last week on the Storm, giving it a bit of a refresh, so lots of paint and lots and lots of new stainless nuts and bolts etc!
STarted off with stripping thr forks back and painting them up, looks much tidier now, then started going through the bike with new stainless bolts and what not, still need to order some more to finish that off tho!
Yesterday I pulled off the rear linkages and was shocked to find the shock pivot bearing well seized, as you can see I had to cut the bolt to get it off the main bracket, then smash the sh1t out off the pin to get it out the bearing! lol 2 others were also wombles, needles in the bearing were rusted and just fell out when got the pin out, but not bad for 18k, cold of been worse! Got some new bearings coming, also gonna pop in some grease nipples to prevent it happening again!
Then tonight, stripped off everything I want powdercoating, everything in the crate is going satin black, wheels and hub gloss black, then a few little brackets etc will be painted up by me!
Oh you can also see my homemade bike stand, as trhere aint no stand on the market which allows the swinger to be removed, so an hour or 2 later and this was the answer, works a treat if a bit ugly though! lol
Still debating whether to get the swinger powdercoated or not?
