AMCQ46 wrote:cybercarl wrote:Well if that's the case then his bike is only putting out just over 64 ponies
maybe they are shire ponies
and it also contradicts what it says on the top left, max power = 101.74 and Max Torque 64.77. But bizarrely nether of the figures correspond exactly to the graph if you use a rule, Mount Everest peaks just past 104 and the straight curve is 102
102 on your ruler is close to 101.7 on the caption. Hp is the LH axis and the smooth curve. Torque is the RH axis and the spiky trace, 64
Flatly, yes I am OCD
Have to hand it to you, I didn't even see that you could zoom it and I read the HP figure as 104, not 101!
It's odd that the torque trace is stretched to fit the scales that way, not seen that done before.
It's still got a nasty dip, though, so the carb adjusting advice still stands. But not as nasty a dip as first appeared.
Flateric, can you ask the dyno operator to re-print the results on normal scales, such as the ones earlier in the thread?
They'll have the data stored on their pc.
