Page 338 of 1529
Posted: Fri May 10, 2013 5:05 pm
by Virt
lloydie wrote:
Tps set to 550ohm and I will set it to 500 once the carbs are balanced and tickover set .
As it's no secret i'm young and stupid, I have to ask. What actually does setting a higher/lower resistance do to the tps? I've seen it get mentioned a couple of times but never understood it
Posted: Fri May 10, 2013 5:17 pm
by MacV2
It's much the same as having a very angry Scot behind you with or without lube...
Posted: Fri May 10, 2013 5:20 pm
by seb421
Dired my electrics out
Posted: Fri May 10, 2013 5:24 pm
by MacV2
seb421 wrote:Dired my electrics out
You haven't been boating in another large puddle have you ?
Posted: Fri May 10, 2013 5:28 pm
by seb421
MacV2 wrote:seb421 wrote:Dired my electrics out
Haha no thankfully tho i was proper shitting it when i got to where that river had burst its banks across the road mind but thankfully the puddle / lake wasn't there this time
Posted: Fri May 10, 2013 6:08 pm
by agentpineapple
Posted: Fri May 10, 2013 6:29 pm
by lloydie
When set correctly 500ohms (900 from factory ) it make it run lots better
Posted: Fri May 10, 2013 6:47 pm
by Gazfirestormowner
Still haven't got the firestorm back so went mental on the tzr. Full strip down engine out disassembled repaired and nearly rebuilt. Just the clutch assembly to replace and then back in the bike ready to be plumbed in and hopefully no leeks this time not bad considering I was gunna leave it till the winter.
Posted: Fri May 10, 2013 8:52 pm
by Virt
lloydie wrote:[
Oh okay..
Rode it to the Bikers Pit Stop meetup, first time it's been ridden in about a week. Jesus christ it feels like sh1t. God knows what my Dad did to the clutch but it's ridiculously far out now and I strongly dislike it. And it's official in that I now have no front suspension, I felt every single bump on the 2 or 3 mile trip and I have never felt so uncomfortable.. Then again I DID ride a VTR with Ohlins just last week so that might have something to do with it
However lots of new parts have arrived in the post today;
Clip ons, clutch cable, little screw thing for the clutch cable that goes near the lever and something else that I forget. Just need to wait for the forks to arrive tuesday and give the bugger enough that it won't instantly fail the MOT. The rest is up to the guy doing the service
Posted: Sat May 11, 2013 2:55 am
by VTRDark
Think of a TPS like a digital version of an old fashioned distributor where you turn the distributor around either clockwise or anticlockwise to advance or retard the timing but not quite as course. Actually the TPS is more like the equivalent of the centrifugal weights inside the distributor.
Technically though the TPS Is Attached to the butterfly flap on the carbs which works via the throttle, so the reading changes as you open the throttle up and the TPS sends a reading to the ECU where it works out whether to advance or retard the ignition timing according to speed and revs. Just like the centrifugal weights in a distributor except it's digital.
But all you need to know is that by setting it to 500 it will allow you to get a smooth low speed steady state cruise. As a side affect it helps with the idle and also helps to eliminate carb coughs as long as everything else is good like your jetting and carbs balanced. Out of the factory the TPS is set to emissions and not performance so it could be set to anything. It's not uncommon for them to be up in the 900's or more or less. They are all different.
Posted: Sat May 11, 2013 6:58 am
by AMCQ46
Carl.....Virt won't remember what a distributor is, how old do you think he is
Posted: Sat May 11, 2013 8:22 am
by MacV2
AMCQ46 wrote:Carl.....Virt won't remember what a distributor is, how old do you think he is
Don't be silly Al of course he knows what a distributor is...It's the bod that hands out the school milk...Oh hang on he won't remember that either will he...
Posted: Sat May 11, 2013 8:44 am
by seb421
fitted MRA Double Bubble screen, got it off ebay delivered for about 20 quid
was dreading the job as the gixxer people made it sound a monumental effort and a bitch of a job but had it done in no time,
dash needs some brute force to pull it out the tabs mind was convinced something was going to break
managed to break one of the bolts, strangely when i was unscrewing them one of the heads of the plastic bolts came off
not sure if i should get blue or black or titanium replacements now....
Posted: Sat May 11, 2013 9:22 am
by AMCQ46
Seb, screen looks good but I am worried about the size of the spider that mist be living in that web in the garage...take care in there
Mac, looks like little frank has competition
by Virt
I'm gonna make the most educated guess i can... It distributes something among something in order to do something. Amirite?
And I remember those Mac. Don't judge me cause of my age
I went to a very crappy and OLD primary school
