Page 341 of 1529
Posted: Mon May 13, 2013 4:44 pm
by seb421
bigspanishmarty wrote:me and carl went for a little ride down into surrey this morning, i needed to pick up this little lot....
http://www.ebay.co.uk/itm/Honda-Firesto ... true&rt=nc
we agreed on £40, i thought that was a bargain, as 2 mirrors are £30
it was a nice little ride and the weather held up, it was bloody windy tho.
Bloody good deal that!
Posted: Wed May 15, 2013 3:33 pm
by mattycoops43
Re checked my timing today, cos I wasn't convinced it wasn't a tooth out on the front when I fitted front Manual CCT, but I did it with a friend who is a bike mechanic and tried to convince me it was just wear. Well, two things showed up, 1 it was a tooth out on the front Ex cam, which I have now corrected, and both my manual CCT's were too tight, all set perfectly now and it's running so nicely, it's like a new bike.
One issue came up though. I fitted the rear CCT at a later date and having done the front one, I tried to do it by 'feel'. Bad idea. I know there was a post a while back about counting the turns in on the front one when measured, then doing the same turns on the rear to save taking it apart. Well, when I originally fitted it, I did it tight by hand and then did it the same number of turns in as we had done on the front, locked it, started it, and it made a horrid noise. Checked it and it was well loose. When I checked today, the inlet cam had jumped 3 teeth.
I am not saying you can't do it this way, but I would say unless you really know what you are doing with CCT's and really know what you are feeling for I would forget it, taking the covers off is easy anyway.
Anyway, I seem to have got away with it, I retimed it, and it's running better than ever, so I can only assume it went the right way when it jumped and has not made contact.
Posted: Wed May 15, 2013 3:42 pm
by AMCQ46
the instructions for the short cut are clearly too vauge and I would reccomend that you have to set the fully in position as tight, not just hand tight to make sure you have overcome any slack in the system and the chain is at full tension....then youu cant count turns out from this stable reference.
lucky escape and good that you have sorted it.
Posted: Wed May 15, 2013 5:35 pm
by lloydie
cleaned and polished my new headers (thank you bsm) i then fitted them 8)
now its ready for london :thumbup:
Posted: Wed May 15, 2013 6:02 pm
by AMCQ46
lloydie wrote:cleaned and polished my new headers (thank you bsm) i then fitted them 8)
just need to sort waterproof trousers if you only found a jacket..........I have some that you can borrow
Posted: Wed May 15, 2013 6:06 pm
by mattycoops43
AMCQ46 wrote:the instructions for the short cut are clearly too vauge and I would reccomend that you have to set the fully in position as tight, not just hand tight to make sure you have overcome any slack in the system and the chain is at full tension....then youu cant count turns out from this stable reference.
I wasn't following those instructions exactly tbh, I just don't think it's clear how bloody careful you need to be, I mean, starting from all the way in tight is one thing, but for a gorilla like me, I am quite capable of winding in and winding it till bits go 'ping'. :shifty:
I definitely wasn't criticising anyone for any particular instructions, (there have been various topics covering it) more just saying, if you are not used to doing the job, maybe better to steer clear and do it belts and braces way to be safe. If someone tries that and gets it wrong it could go very pear shaped!
Posted: Wed May 15, 2013 6:07 pm
by agentpineapple
i told ya they were good headers..... :thumbup:
glad to hear your ready to rock out with your c..k out................. :wink:
i'll see you in londonshire on sunday.
Posted: Wed May 15, 2013 6:14 pm
by Wicky
mattycoops43 wrote:I wasn't following those instructions exactly tbh, I just don't think it's clear how bloody careful you need to be, I mean, starting from all the way in tight is one thing, but for a gorilla like me, I am quite capable of winding in and winding it till bits go 'ping'. :shifty:
http://www.kriegercamchaintensioners.com
Welcome to Krieger's Cam Chain Tensioners.
...finger tightening the cam chain tensioner to make sure all play is out, then back the thru bolt 1/8 turn and tighten lock nut. (static setting)
It came to my attention that there are individuals who either post instruction or have even put up Youtube videos giving misinformation about cam chain adjustment. It appears some will tell you to tighten the adjustment until the idle of the engine starts to drop. Others may say to tighten the adjustment until there is a squeal! What do these people think is happening mechanically when the engine is dragged down by excessive friction and even something causing a squeal? The cams run in the machined bearing surface of a rather expensive head. There is a film of a few thousandths of an inch between the cam journal and the head - about the thickness of a hair or two. Break that film and you have metal to metal contact.
Do you think it makes sense to tighten the cam drive until there is so much drag as to cause the engine to bog or squeal? Chains are meant to run with as little slack as possible, but NOT under any actual tension. (For some of you who played with bicycles you may have overtightened bicycle chains before, remember how they worked, then how much better they worked when slightly loose?) These well meaning people are making a serious error in performing adjustments in the fashions mentioned. If they don't cause immediate damage of some sort they will promote premature wear on components due to unnecessary tightness of the cam drive line, all rather costly to deal with..
The adjustment of a manual tensioner is simple and is printed here in directions that are on the page "About Tensioners". Take a look to see how to do it right. Don't risk ruining an engine with the mechanically poor adjustment techniques posted out there, no matter how well intentioned the posters may be. As I've mentioned before, from the mechanical point of view I'd rather run just a tiny bit loose than too tight. With the methods in our instructions, you will be very near ideal adjustment erring to the loose side if any and only by a few thousandths of an inch (one full turn of an M8-1.25 bolt is .050", so 1/8 turn is about .006", not enough chain play to cause any apprieciable wear and far less play than any failing OEM tensioner).
Posted: Wed May 15, 2013 6:16 pm
by lloydie
thanks al that reminds me i need to try the jacket on as ive had it 17 years and im a little larger now :oops:
if it stays like this i might pop down to hatton later .
they were very nice and shiny till i test road it bsm now they are going brown again lol.
you cant half feel the extra weight from these standard cans when riding it not nice at all .
well it should sper me on to save up for the akros
Posted: Wed May 15, 2013 7:08 pm
by VTRDark
Re checked my timing today.......
Well done matty. You where lucky that jump was not any more than 3 teeth. That is right on the borderline, any more than that and there would have possibly been damage. And I agree doing things by feel is a gamble. why cut corners when it's so easy to just remove the covers.
Today I investigated my Dr Honda copies and put the two standard tall stacks back in. Around the base of the Dr copies the paint even though I sprayed in petrol resistant lacquer has started to come off :( there's little splatters of aluminium paint stuck to the bottom of the airbox and a little across the tops of the slides, the rest of it has been combusted. :lol: There's no signs of any cracking up from vibrations and the stacks have held up well apart from the paint. I think I need to find some sort of plastic or epoxy coating for them. Either that or just buy some billits :( I may even just stick with the standard long ones. The Dr copy stacks defiantly richened things up as soon as I put them on as I could smell it.
Posted: Wed May 15, 2013 7:14 pm
by bigtwinthing
simply rode it to work (instead of the van) and fook me, its 93 miles on the bike( 21 in the van) and you turn up late!!!, so i left early to check, and yep its still 93 miles!!!. I may do that again when iam pissed off, cause it makes you smile. :D
Posted: Wed May 15, 2013 7:28 pm
by Virt
bigtwinthing wrote:simply rode it to work (instead of the van) and fook me, its 93 miles on the bike( 21 in the van) and you turn up late!!!, so i left early to check, and yep its still 93 miles!!!. I may do that again when iam pissed off, cause it makes you smile. :D
I might steal this excuse from you when I start commuting with the storm :lol:
Posted: Wed May 15, 2013 9:00 pm
by lloydie
its a bugger using a full tank to get to work and the same on the way home . :thumbup:
Posted: Wed May 15, 2013 10:53 pm
by callam_nffc
removed the stupid lowered hagon and fitted a standard unit for the time being, my god it feels so much better!
Posted: Wed May 15, 2013 10:57 pm
by Virt
Well the forks didn't fit the hornet and the brakes didn't fit the forks. So no idea what is happening as the ad specifically said... :thumbdown: had to buy a hornet front end... They cost a ridiculous amount :/
