Nickso
Post by Nickso »
Fitted an R1 reg/rec after my one died.
Now need to buy a battery to replace the 6 month old one that got killed by the reg/rec. :thumbdown:
Bloody thrashed it senseless.
Sorry, world......
I needed that.
I've fitted the MWR air filter, but this time inside the airbox, lid fitted as (for me) usual.
Remember it's an enlarged airbox, bigger snorkel etc.
Sounds.....different, but runs ok. Not as strong mid range, but top is good, by feel, anyway.
I may even dyno it back to back with the K+N, just to see what's going on.
seb421
Post by seb421 »
Was going to clean it but its due to rain shortly and the commute will be coverd in shite again in two minutes flat
Just Swapped my Carbon Fibre rear fender for the same one but in white as felt it would go better with the blue and white
this is the old one, think i'm going to sell it not sure, still need to fit the front carbon fibre one, carbon one might look better with carbon fibre front and rear fitted
Carbon looks better Seb
seb421
Post by seb421 »
From a distance I think the white will look better when the bike is clean.... Hopefully
Griff1977
Post by Griff1977 »
lloydie wrote:Carbon looks better Seb
+1
Immediate plans:Clean it!
darkember
Post by darkember »
TPS mod done today. Managed to get it from 884 down to 560 with only have to raise the tank. Waiting for the carb balancing tool to arrive to check the synchronization before I make the decision to b8stard the unit to get it to 500.
seb421
Post by seb421 »
Spent three hours making this bush for the clutch lever as the one it should have had was missing :thumbdown:
this polymer bush took me ages sanding it down from a large 50 pence size, had to keep sanding a little then turn then sand a little then turn .. on and on and on and on three hours later it was ready to be tapped in with the mallet, clutch now feels and works as it should have
Thanks potkat for the heads up with that one i would have noticed when i took lever off but he got it before i took it off
Fits perfect and works perfect will do for now
Should have used a grinder or dremmel :confused :confused Well done though, that should sort it out. :thumbup:
I thrashed mine through the tunnel. :lol:
seb421
Post by seb421 »
cybercarl wrote:Should have used a grinder or dremmel :confused :confused Well done though, that should sort it out. :thumbup:
Don't have one mate always wanted one mind
seb you fancy a ride in a bit mate - going down to builth wells via crossgates about 11am
seb421
Post by seb421 »
Sorry mate with the bird for the day
any other time i'd say you was a lame crouton, but having seen your mrs, you are excused :erection:
Gave the mixtures .5 turn in and now it pics up better and I'm back to 100 mike to light :-)
Same here, but now I have got one I wished I had it sooner. It's amazing how much use it's getting. I'm going to trim the bottom off the back yard gate today as it keeps dragging on the floor.
