a bit of spondoness.
Re: a bit of spondoness.
Flatline wrote: Sat Sep 08, 2018 9:37 am Dymag will do crack testing
It's not the crack you want to test, it's the wheel, to make sure it hasn't got any.
Powder coating will hold it all together AND hide the cracks, you could try that.
Wonder why Dymag chose that particular first syllable for their wheels? :think:
I would say it's more to do with life expectancy than checking the wheel for cracks, although obviously you don't want any crack :)
They are wheel sex i have to say. iv x-rayed mine several times just for peace of mind. it was the rear carrier that bolts onto the wheel that tried to kill me :eek2 :eek2 . but i really want the spondon swinger back into the bike as much as i like the one in atm..
sirch345 wrote: Sun Sep 09, 2018 11:33 am
I think you're right, Chris; having a wheel break up under you is likely to shorten your life expectancy.....
so that leaves me with the problem, i want the spondon swingarm back into it. but storm wheels are far to narrow :sad2 :sad2 ..
fabiostar wrote: Mon Sep 10, 2018 9:09 pm so that leaves me with the problem, i want the spondon swingarm back into it. but storm wheels are far to narrow :sad2 :sad2 ..
May be you can find a wider wheel that will work, I'm guessing the Spondon s/arm takes a 6" wheel :?:
sirch345 wrote: Tue Sep 11, 2018 10:39 pm
yeah chris it runs a 6" rim....i have been told to hunt down a ZRX 11/1200 rear wheel, they are 3 spoke like the dymags. the spondon swinger uses a huge axle aswell so i may do some googling on kwak rear wheels..
kenmoore
Post by kenmoore »
Find a suitable rear wheel and get that swinger back in.
Your bike is pure porn and deserves the spondon touch.
There must be loads of rear wheels out there that will fit, just need to find one and as Barry White said "Get it on" :thumbup:
South Coast
New South Wales
Australia
fabiostar wrote: Wed Sep 12, 2018 8:25 pm
I'm sure if anyone can do it Rob, you can :thumbup:
i can see a long winter of bike breakers and driving round the country with a measuring tape ahead :eek2 :eek2 :eek2
fabiostar wrote: Fri Sep 14, 2018 8:54 am i can see a long winter of bike breakers and driving round the country with a measuring tape ahead :eek2 :eek2 :eek2
That should do the trick :)
prob the last sunny day of the year so filled its neck with super unleaded for a gallop then into surgery for the winter refit, even tho its finished.. :eek2 :eek2 :eek2 well a few wee jobs to do so it will look slightly different next time it appears...
Flatline
Post by Flatline »
Nice
After mucho thought and head scratching about wheels.. im wrapping my rear dymag up and keeping it safe but i cant bring myself to use or trust one on the rear. just not worth getting it wrong, i had a lucky escape and il take that as a warning..
the hunt is still on to get the wheel/spondon swing arm all to fit but either way il not fret to much as the swingarm im using will do the job atm..
to be continued.......................................... :p
fabiostar wrote: Mon Oct 29, 2018 9:48 pm After mucho thought and head scratching about wheels.. im wrapping my rear dymag up and keeping it safe but i cant bring myself to use or trust one on the rear. just not worth getting it wrong, i had a lucky escape and il take that as a warning..
I think you're a sensible man regarding that rear wheel.
Nothing too drastic over the winter I hope :wink: :problem:
As much as I'm sure you would like the Spondon swingarm fitted, I think the one you're using looks good,
