lumpyv
Post by lumpyv »
today matthew I have changed my oil and filter
I got gulf semi synthetic 10w 40 off the e bay with a hi-flow filter chucked in for 26 quid .
must say its impressive, that oil has done nearly 5000 miles and was hardly discoloured. I did,nt need to top it up at all in that time. the old filter was a K&N
perhaps I need to thrash it more ??
Or clean the inside of the oil window.....
chris freckle
Post by chris freckle »
Found time to strip the carbs of today, hoping to find a dynojet kit! no such luck, completly standard, choke cable knackered, seems to be sticking on, hopefully a new one will sort it, the annoying thing is that one of the rubber pieces that hold the cable into the carb is split and it comes with the valve at the bargain price of £44.00 which is more than the cable. :sad2
Fitted forks /wheels / body work
Nearly done now
Ckennedy
Post by Ckennedy »
lloydie wrote:Fitted forks /wheels / body work
Nearly done now
Its about bleeding time :lol: :lol:
Today I have dreamt about riding mine, that's about it :roll:
Nearly done now
you in the dog house too then :Banned:
Gazfirestormowner
Post by Gazfirestormowner »
Just looked at the storm but got loads done to the Tzr chain and sprockets on, new rear disc, fitted the carbs and ran all cables and pipes, battery on charge, air box and ducts on, only things left to do is radiator and coolants, rear brake caliper and pads, power valve cables, 2 stroke oil tank to mount, fuel tank and fairings then I guess run it and get it ready for mot :thumbup:
Virt
Post by Virt »
Gazfirestormowner wrote:Just looked at the storm but got loads done to the Tzr chain and sprockets on, new rear disc, fitted the carbs and ran all cables and pipes, battery on charge, air box and ducts on, only things left to do is radiator and coolants, rear brake caliper and pads, power valve cables, 2 stroke oil tank to mount, fuel tank and fairings then I guess run it and get it ready for mot :thumbup:
Don't forget about that ride you promised me :wink:
Gazfirestormowner
Was I drunk lol
Just been to see about a daytime mot only thing it needs is road tyres and a horn
No brake lights indicators or speedo or anything lol
Flirting again Virt :roll:
Virt
Post by Virt »
No Gaz, definitely sober :roll: :roll: :lol:
Where did you go, RM or R&J's?
When am I not flirting? I have needs :(
Gazfirestormowner
R&j's mate always take them their as they always pass lol
Virt
Post by Virt »
Good point. We always use him for that reason
Bought an led rear light to possibly fit but probably mutilate for its clear lens :twisted: Cheers to Kev L for the idea :thumbup:
Mav617
Post by Mav617 »
Put front fairing back together - 8 self tappers and 4 side bracket screws (shouldered) from David Silvers, £20 FFS :eek2
