Put the re-jetted carbs and "filtered" lid on today...... looks awesome. The front of the tank is lifted slightly and the foam seals up against the tank right to the front, leaving the front "mouth" open. The air is now fre to come in from the normal area (directly behind the steering head) as well as from the gap at the front of the tank; she won't be starving for air nowmik_str wrote:Here are some pics of my modded airbox lid with integrated filter. Note that the shield on the inside can be removed (will likely try it with and without).
Looking forward to firing it up when the temps warms a bit.
