robbie 131
Post by robbie 131 »
ah ok im with ya .... so if i was to get the progressive fork springs what oil should be used then bud :? ... i weigh 15 stone and 6ft 3 mate if that helps at all ?????
and cheers for the heads up :thumbup: lol took it out today as i ride everyday lol and it felt a hundred times better than the rocking horse it was before :D :D :D
just trying to bed in the new pads and seals then it should stop just aswell as it feels to ride atm :D :D
I don't suffer from insanity; I enjoy every minute of it
Ckennedy
Post by Ckennedy »
Most people would use the 10w or 7.5 with most springs. I think the 7.5w works better with the internals of the forks if I remember rightly.
Sent from my HTC Sensation XE with Beats Audio Z715e using Tapatalk
robbie 131
ahh right ok mate weel i shall ride it this week then next weekend i shall have it apart again and switch the oils ... thanks again guys :thumbup:
Ckennedy
Post by Ckennedy »
Don't quote me on that though. I'm sure someone more knowledgeable will be along to let you know more.
Yep 7.5w is the best members have found to work with the vtr
It depends, really.
Standard is 10, but your choice is to either go heavier and that can work if the standard spring is too light for your weight and riding style.
I'd really only recommend it if you are finding that the std damping (combined rebound and compression) isn't enough- your comment about it pogoing might be an indicator here, assuming that you've tried to adjust but run out of adjustment.
The Std springs are usually a little too stiff for most people, but an oil change and clean (as you've found) gets them back to a usable state.
Thing is you don't notice it going off slowly, but one day you notice, and it'll never be right for you after that.
Mostly, a slightly lower rated spring, 7.5 weight oil and an air gap of 1430-140mm is about right- you won't be disappointed with those settings, but very few people bother to play around with air gaps etc to see what they like best. Mostly, like you, they clean and change the oil, and find it feels better, then leave it alone.
But try changing the oil and report back what you find- I'd expect that 10 would be about right, as your height would put more weight higher up over the front wheel, and you don't want it diving- especially so if you have a 6mm shock spacer in place.
Different strokes for different folks- the way you ride, how hard you are on the brakes, how much you lean it over- all of these affect an ideal setting- it's personal, otherwise there would be one setting and we'd all have that set up.
robbie 131
i had ran out of adjustment bud ...... i tried an air gap of 120 with the 15 weight but it was so hard i couldn't move it lol :( i don't proclaim to be any good with suspension but i'm confident enough to strip and keep playing till it feels right .... if that makes sense :?
i had decided to go with the 15 weight oil after a friend that has a vtr said that he found it the best .... but i am always willing to explore different avenues ..... im only young so its all a big learning curve ..
tony as for keeping ya posted im just putting the 10 weight oil in now with the gap of 140 so i shall be done in a hour or so ( depends on whats for dinner :D ) then i will take it down the country roads near mine and let you all know how it feels :thumbup:
thanks again guys really appreciate it :) i love this forum :thumbup:
tony.mon wrote: The Std springs are usually a little too stiff for most people, .
Tony, did you get front and back mixed up? Front too soft rear to hard in my mind?
Refitted steering stem/yolks etc.complete with new All balls taper bearings, checked all disc bobbins spin freely, cleaned front wheel, discs and calipers. Refitted recently Rogered/painted forks,wheel, calipers etc. Also collected swinger from painters, no reactions this time and looking lovely :D :thumbup:
your forks are looking good watty, I need to do mine at the end of the year.
agentpineapple wrote:your forks are looking good watty, I need to do mine at the end of the year.
Yeah i'm proper chuffed with them mate,cheers :D
Mav617
Post by Mav617 »
Looking good Watty!
Hey watty was that another day in the office. :lol:
Yep they do look great ( want to do mine ?)
cybercarl wrote:Hey watty was that another day in the office. :lol:
Sure was :D , but with plenty of tea,coffee and biscuit breaks 8O , oh, and sunday lunch :lol:
