chain Lube
chain Lube
Anyone ever use litium grease for chain lube? I was wondering if its a)really suitable and b)cost effective.
Thks.
Thks.
- RedStormV
- Location: West Yorks (Bronte Country) - Home of the Negro Lesbian Cornet Players
- Contact:
Not really suited for lubing chains - other than it's a grease.
Likely to get fling onto tyre edge which is less than ideal
I've found that Wurth High Performance Dry chain lube is 'probably' the best. Certainly get zero 'fling' like you still get with others that claim they don't.
It's certainly not the cheapest on the market, but well worth (wurth ) the money IMO.
http://www.sportsbikeshop.co.uk/motorcy ... od/80/3586
(maybe cheaper elsewhere on the net - just first Google link I found)
Motul also do a good lube, which is cheaper, but still a little 'flingy' by comparison. The beauty of this though, is that you can get it in a nice small can which is ideal for popping under the seat for emergency 'boredom set in' lube jobs while away.
http://www.opieoils.co.uk/p-951-motul-c ... hains.aspx
Pretty sure we (FirestormUK) get a reduction at Opie oils too
HTH
Rossi, really messes with your mind!!!!! Muaahahahaha
HTH
Agree 100% Wurth High pref dry lube (make sure it the right stuff!)
Looks after your chain (2 years and counting) Doesn't need constant lubing and whilst it is expensive to buy you won't go through as fast or be cleaning it off everything.
Don't pay more than a tenner inc postage.
This guy has good price and service
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0057081831
"military intelligence, two words combined that can't make sense"
- bikerpiker
chain oil,grease ,lube
Right ,here goes
I purchased my bike roughly 1 year ago,(ebay 2nd chance offer) when i bought it the chain was at half a segment off the Max adjustment indicator, infact i got a bit deducted off the price cos of that
i have done roughly 2,500 miles and i swear not once have i had to adjust the chain. It still feels exactly the same amount of free play at mid-point as it was when i bought it.
I've got 3 cans of various half used chain lubes on the shelf in my garage,but dont use any of it,,, since i bought the 'storm i use.......wait for it.................... Castrol GTX ,which i put on with a paint brush when the chain is rotating :!
Strange but true
Strange but true
I've used Mobil 1 sparingly on my last few bikes and it works a treat, don't put too much on and you don't end up spraying the underneath of the seat and tyre. Consequently chains and sprockets last forever. I have been averse to sticky chain lubes as I find that they end up attracting grit and road cak which you then have to clean off! Seems oxy-moronic. I only asked about the grease as I have some and I can't see it getting used much otherwise. Thanks.
don't even know what lithium grease is? anyone?
The brushing on oil method is fine (and bloody good value for money) but I guarantee the wurth stuff is cleaner, less hassle and does the job as well. It actually cleans sh*te off the chain as you apply it as it is basically a dry powder lube in a solvent. As you spray it on it washes away any grime and leaves a very thin residue.
I'm not a salesman for the stuff but I am very lazy when it comes to bike maintenance. Not adjusted my chain for over a year either! Says a lot for the storm and the lubes!
- bikerpiker
- LotusSevenMan
- bikerpiker
- RedStormV
- Contact:
S'pose it works, but can't see the point, might as well use Lithium or just any old grease.pariah wrote:I,ve been brought up to use copper grease.
Idea of copper grease is to stop steel bolts ceasing up in aluminium casings etc. Chemical reaction between the 2 metals, that's not going to happen on a chain
