Just a wii request that if we knows where you is living, the locality like, then may be easier to offer help. ie if any one is in the basingstoke area for example i may be able to offer assistance or at least a second opinion on like a noise or whatever, but not for some one in the borders, comprend-a
Similar for southeast/london, can help out or offer advice- competent for most things mechanical and electrical.
A fellow Stormer locally can be useful.
Sometimes it's the special tools, often its having done it before, mostly it's having the confidence to get stuck in.
BUT:
Worth checking the forum for info first. (RTFM )
So please add your location to your posting ID, it appears on the left of all of your posts.
(and you know who you can safely insult, as they're miles away )
Lincolnshire for me. May be able to help and offer advice. Always happy to make a brew for a fellow biker.
Only when the wind is blowing in the right direction to keep the smell at bay....
You're thinking of Southend.
Some chancer nicked the end of the sewage discharge pipe at low tide, and the sewage discharges straight onto the beach now.
I learnt to windsurf there- great motivation, you don't want to fall in......
Not so much swimming as going through the motions
