AMQ46's storm
Re: AMQ46's storm
I see what you mean about not much wheel showing with those disc's, they look ma-whoo-sive :Woohoo1:
Looking good Al :thumbup:
Re: AMQ46's storm
Doing good al .
Your going to love it
Re: AMQ46's storm
These are the bar clamps I am using. Just need to shorten the bolts and give them a good shot lasting to clean them up.
Sent from my iPad using Tapatalk
Re: AMQ46's storm
that front end looks proper order Al.... :D :D :D
Re: AMQ46's storm
Swapped the tyre over from the old front wheel, all parts removed, brgs and spindles greased and refitted at the correct torque.
Made a mounting bracket for the heated grip switch, fitted the new radial 19mm master cyl and sorted out the brake hose routing.
This adapter or from HEL performance is a great way to keep your existing hoses when you convert from axial master cyl to radial
Re: AMQ46's storm
Brakes bled, wires all cable tied out of the way, sag set, fairing and tank back on.
Finished but not the weather for a test ride, so I ran it up to temperature and made some brum Brum noises and put it away again.
Just waiting for a front master cyl clamp with a screw boss on it so I can knock up a bracket to support the fluid reservoir
Varastorm
Re: AMQ46's storm
Post by Varastorm »
That looks the dogs ballocks AmCQ 10/10 :thumbup:
Cracking job, time to crack a cold one I recon :clap: :clap: :thumbup:
Re: AMQ46's storm
Proper job looks spanking
Re: AMQ46's storm
Looks really nice Al, well done. :clap:
vtwin goody
Re: AMQ46's storm
Post by vtwin goody »
Very nice mate,very nice indeed :clap:
StormyRob
Re: AMQ46's storm
Post by StormyRob »
Fantastic mate!
That front end!!!!! Amazing
Re: AMQ46's storm
Very very nice. Cracking job. :thumbup:
lumpyv
Re: AMQ46's storm
Post by lumpyv »
preferred it standard .......
:D :D :D :D
only joking , it looks great. looking forward to your impressions when you give it a road test :thumbup:
bigtwinthing
Re: AMQ46's storm
Post by bigtwinthing »
Great job Al, just chop the back end off and it will be perfect :thumbup:
Re: AMQ46's storm
Looking very nice. It was almost worth losing the original one!
Now for the fun bit; finding a road setting and a trackdays setting.
Let the tweaking commence.....
