high set exhaust
rocoepecotrain
high set exhaust
Post by rocoepecotrain »
Can anyone direct me to a site or somewhere where I can get high set exhaust brackets?? I have the cans and the link pipes but cant find the brackets that fit to the rear footpegs anywhere. Some help would be ace!
regards
Roscoe 8O :oops: :oops:
kevg
Re: high set exhaust
Post by kevg »
Try somewhere like blue flame, i think they are still on the go, they might be able to provide you with brackets and clamps to suite the can shape you have.
cheerz
kev
rocoepecotrain
cheers kev, i'll give them a ring. many thanks. Roscoe :clap: :clap:
rst steve
Post by rst steve »
Just make your own. Bit of 6mm ally cut and drilled then give it a bit of a polish job done and a lot more satisfing than buying one. :thumbup:
rocoepecotrain
I think thats the route i'm going down. I have tried everywhere and its just too much hassle. Time to get the dremel out. Cheers for all the replies.
Roscoe :thumbup: :thumbup: :wave:
Zakalwe
Post by Zakalwe »
rocoepecotrain wrote:I think thats the route i'm going down. I have tried everywhere and its just too much hassle. Time to get the dremel out. Cheers for all the replies.
Try MTC Exhausts. They make high levels for the SP1....maybe the brackets will suit. Martin at MTC is a top fellow and very helpful.
Entia non sunt multiplicanda praeter necessitatem
cliveyandrews
Post by cliveyandrews »
I have a set of hi-level brackets that I can make a cardboard template from....
(I wanna copy them and move the silencer back - so I can reduce the link pipe angle, and make the stubbbies a bit neater!)
:clap:
Audi, Vide, Tace
mik_str
Post by mik_str »
Check eBay. I have come across these quite often during searches.
