Page 1 of 1
Reg/Rectifier
Posted: Wed Mar 03, 2010 12:32 pm
by simo
Hi, just picking your brains again. Has anybody tried one of those cheap rectifiers on Fleabay from China? They're about a tenner plus. Or do you think
pay abit more for a second hand one? Thanks.
This bloody computor
Re: Reg/Rectifier
Posted: Wed Mar 03, 2010 3:10 pm
by storminateacup
Just remember when trying to save a tenner that when the reg/rec goes it usually takes the battery with it..........could be another £60 for a battery.
Re: Reg/Rectifier
Posted: Wed Mar 03, 2010 4:40 pm
by Mick B
I used an R6 one and its been spot on. Wouldn't cut corners with cheap unproven stuff
Re: Reg/Rectifier
Posted: Thu Mar 04, 2010 10:40 am
by tony.mon
R6 is fine, R1 is a bit quicker.
Re: Reg/Rectifier
Posted: Wed Mar 10, 2010 11:20 am
by simo
Thank you all for your help. All sorted now. In addition to the modification article,i took time to take the connectors out of the multi plug so did'nt have to chop the wires. Filled /slotted the holes in the R1 reg/rec.so could use both bolt holes and the flasher unit stays in place. OH and i put shrink wrap on the wires as insulation before fitting. Tidy job.
Thanks again
