Hello
Phoenix
Hello
Post by Phoenix »
Not quite sure where to start but hello to everyone, I am the owner of a 1998 Firestorm FW in black although I have gone crazy with just about anything gold from Pro-Bolt. The bike has a chequered history although only two owners including myself appear on the log book. As soon as I work out the system I will down load some picture, although a couple did appear in Streetfighter a couple of months ago.
Anotherbikerbabe
Re: Hello
Post by Anotherbikerbabe »
Hello & welcome
Great bike aren't they! I love mine. Enjoy the forum as guys are really helpful. ABB. :thumbup:
Re: Hello
Chequered, with gold Pro-Bolts?
Cant wait for them pix....
Hi, BTW....
Re: Hello
:D Welcome Aboard :D
Just host your pictures on another site like Flicker or Photo bucket and then post a link on here :thumbup: Simples :thumbup:
Jbrebel
Re: Hello
Post by Jbrebel »
Welcome to the forum :thumbup:
SP1's rock!
Phoenix
Suspension settings
Post by Phoenix »
I wonder if anyone can help, i keep hearing about returning the front forks back to standard settings, does anyone know what these are? I dont have any settings that use the standard springs and weight of oil? Although I do realise that at 12 years old the forks may need a major overhaul. I have checked the tyres (36/42) and the brakes (for drag), all the bolts seem nipped up correctly but the bike tends to oscilate from the front end at both low and high speed 40-60 mph seems ok.
Re: Hello
what do you mean by oscillate?
might just be the wheels want balancing,or depending on the mileage could be wheel bearings, headstock bearings, warped discs. egged tyre...
copy the pdf manual in the workshop section & get to know the bike better :thumbup:
Re: Hello
No matter what's been done to your front end it shouldn't oscillate.
But if you want I have some spare standard fork springs, seem to recall Honda put 10 or 15wt in, Haynes'll tell you for sure.
+1 on other reasons, though.
Tyres, balance, pressures and do the wheels line up ok?
Don't trust the marks on the swingarm, they're always out.
Re: Hello
Welcome aboard Phoenix :thumbup:
I hope you've cured your oscillating problem, or at least figured out what's causing it.
Phoenix
Suspension gremlins
Post by Phoenix »
Many thanks for the advice, still not sure what the problem is with the bike but I will sort it. Asthe Storm is twelve years old the front end may just be a bit tired. I think is running the standard weight oil and when I measured (on the work top in the kitchen) one of the springs is very slightly longer than the other, I think new springs are required, has anyone replaced theirs and if so with what manufacturerhas achieved the best results?
Re: Hello
go to wemoto and treat the bike to some wirth progressive springs (the cheaper hagon are rough as crouton ive been informed...)
vastly improves the handling of the bike in corners & when braking
also re the 'oscillation', while you have the bike apart, check for wear inernally on the spacers and sliders.
tapered headstock bearings make the steering feel more positive too - not got the part number to hand but it's listed on wemoto.
marlbororman
Re: Hello
Post by marlbororman »
So are they not tapered standard???? coz mine where when it was apart, and where in very good nick, but in need of adjustment.
Re: Hello
yup the standard springs are progressively wound - tighter coils at one end than tother, but are still sh1t!
when i took my old ones out i was surprised to find they were so short and progressive.
then i took my spare ones (yours) apart and they were the same 8O
marlbororman
Re: Hello
I was actually on about the headstock bearings :) the one in the bttom yolk and the one at the top :)
Re: Hello
marlbororman wrote:So are they not tapered standard???? coz mine where when it was apart, and where in very good nick, but in need of adjustment.
Ian,
No, the standard head race bearings are the ball bearing type. Someone must have replaced yours at some point. Tapered head bearings are the way to go IMHO, much better.
