Page 1 of 1
Daylight running lights on Firestorm
Posted: Sun Dec 12, 2010 4:01 pm
by slipper 1
Thought I would brighten up the front end of my Firestorm by fitting some daylight running lights. I bought some led indicator mirrors and removed the yellow leds, had them replaced with high intensity led's, fitted a seperate switch and hey presto if they cant hear me coming they are going to see me ! Also fitted a high output led board to the standard day running light.
Re: Daylight running lights on Firestorm
Posted: Sun Dec 12, 2010 5:01 pm
by slipper 1
I havent noticed it so far, but if they start I will need to mount them on the standard mirror mount which should sort it.
Posted: Sun Dec 12, 2010 5:10 pm
by benny hedges
best lamp ive found so far for the day lamp instead of leds (whic aren't really that bright) is a 25w 12v halogen bulb meant for use in mini low voltage spotlights, like the sunken ones you have in the kitchen etc...
they runn pretty cool, are bright as crouton & are a fiver for 2 in b&q.
tried a few different types of superbright led and theyre poo.
you cant hardly see them from a distance and they look dim compared to the headlight.
try them - you will be surprised
Posted: Mon Dec 13, 2010 1:01 pm
by cliveyandrews
I like that touch with the mirrors.............
