Well the sp1 went for its MOT today
Ended up hanging around for the MOT for what seemed like ages
Till the guy walked out with MOT in hand with an advisory note attached
He explained that the advisory was for the exhausts being a bit noisy
Lol and that’s with a set of DB killers in
MOT today
Re: MOT today
Warby, it's always (well for me at least ) a good feeling to get the bike through another mot
I hope you have the original cans at home, as it could be you'll need them in the future,
Re: MOT today
You don't have to do a thing with an advisory note, it's for your advice only.
And you already knew it was a bit noisy!
BTW, if you get a producer you don't need to show them the advisory note part.
Re: MOT today
They don’t do a DB test as such it’s down to the examiner if he thinks there to loud
bike didn't come with the standard cans any way Chris but I’m not bothered by it just give me that hummmmmmmmm feeling for when the DB killers came out after the MOT and it’s not as loud as the storm was lol
They said the top end for the DB reading would be 97 db and its no were near that with the killers in Tony probably below it with them out. It’s just booming like all V twins do when there in a confined space and the guys not use to two huge explosions instead of 4 tinny ones
- benny hedges
Re: MOT today
the place i usually use, the guy is half deaf!
i asked him about exhausts last time i was there as i noticed him putting an emissions tester up a goldwing's orifice....
i thought they may have introduced emission testing without telling us, but he was just checking for oil burning.
regarding db testing, he said (quite sensibly) there's no point cos it depends how the bike is ridden,,, and if it passes, you will only put your loud ones back on after the test.
i went somewhere else to get the zx750 tested and got a cautionary on that for noise its not a fraction as loud as the storm so i wont be going there again lol!
what does matter is track days. before i put baffles in mine i got it tested at 109db at 6k revs, and even then i crept it up there as gently as i could - at full bore, full rpm under load it sounds like a vulcan taking off.
so after fitting baffles i got it down to 99 which is quite a result imo, has to be 103 max for the track.
seen a few guys get turned away & theyve been frantically running round the garages trying to borrow some baffles - you can imagine how much of a pisser it would be if you can't get on.
(at cadwell btw the guys are usually very accomodating with noise levels and will back away from the bike until they get a low enough reading, instead of the usual 1m distance)
