flywheel removal bolt
im after a bolt or to purchase a bolt to help with removing the flywheel , have two old engines but want to have a turned down flywheel in advance of stripping my storm does anyone know exactly what i have to have made or one to borrow or buy
Re: flywheel removal bolt
Although I've not had to use one on mine, I'm fairly confident that it is an M20x1.5 Right Hand puller. Demon tweaks has one for a whopping £35 while Motion Pro in the states do one for a lot less. I think this size of puller is common to a fair few bikes. I have a puller set somewhere (used on a CBX750 and a VT500) and while I'm not 100% sure it fits the Storm, I'd be surprised if it didn't.
If you are stuck and are close by, I'll dig mine out so you're welcome to borrow mine - or maybe someone closer to you might do likewise. If you end up having one fabricated, all you need to do is make sure you have a hole through the shaft into which you slide a drift that when tapped over snaps the taper fit out.
{Edit} Benny states it's an M22 so I was mistaken. Sorry. Still sure I have one though.
Starts with a R. Rrrrrrrr. Motorbike!
- benny hedges
a few options....
it is most definately m22x1.5 right hand btw
http://cgi.ebay.co.uk/PUCH-MAXI-AND-OTH ... _889wt_700
cheaper option.... sump plug, fiat, seat etc
http://cgi.ebay.co.uk/SUMP-PLUG-M22-x-1 ... 1187wt_700
or loads of different models of wheel bolt & wheel stud.
if you cba paying just go the scrapyard & get a wheel bolt or sump plug
- babysitter
Hi Machine Mart do a Laser Motorbike Fly Wheel Puller for £17.99
http://www.machinemart.co.uk/shop/produ ... le-tools-2
Harley Davidson Roadking 1690 / Harley Davidson 1200 Sportster
54 Honda Varadero XL1000 / Honda Firestorm Red,/ BSA B40WD Trials,
/Audi TT 225 / Foard Transit T300/ VW Touareg
- benny hedges
dont waste your money. it wont fit.babysitter wrote:Hi Machine Mart do a Laser Motorbike Fly Wheel Puller for £17.99
you need the right size and the right size is m22x1.5
