Need to do mine fairly quickly, and im wondering if anyone thinks these are ok, or do they look too cheap?
http://cgi.ebay.co.uk/Honda-VTR1000-F-9 ... 646wt_1139
Also - im changing mine because it knocks a little bit when I brake. But mainly it vibrates and wobbles the steering under hard braking between 70 and 30 mph, though im not 100% sure that head bearings can cause vibration and wobble....
Head bearing
- Miztaziggy
Re: Head bearing
Oh and tightening the old ones - is it possible on stock head bearings and is it easy to do?
- benny hedges
Re: Head bearing
last set i bought were from http://www.bitzforbikes.co.uk/ £30 for the set for kyoto bearings (quality kit)
they have an open day this weekend with another 25% off too btw.
(plus a free burger & brew)
theyre in rochdale, not far from you
best ring up first and check they have them in, but bet they have
- Stormer Dave
Re: Head bearing
Same as Benny........from same place....
Job Done...
Benny whats that belly pan on yours.....
Where do you get em from....
Job Done...
complex personalities lead you to v-twin happiness......if you can get to turn in.......that is.....
- benny hedges
Re: Head bearing
thats a pyramid belly matey.... its in the garage atm as it's currently wearing a skidmarx one.
i was going to flog the pyramid one but decided to keep hold of it.
decided to respray it and put it back on as it overheats a bit with the closer fitting skidmarx lowers, though they do fit nicer.
theyre quite expensive new now. try m&p plastics...
they forgot to charge me for mine
- Miztaziggy
Re: Head bearing
Nice one guys
And wtf?
Brake disks £106 each? So over £200 to change both front ones?
Oh crap, im hoping that isnt what is causing my wobble....
And wtf?
- Miztaziggy
Re: Head bearing
When you changed your head bearings, did you need the seals too? And do the kits from Kyoto have seals with them?
I phoned bizforbikes and they dont sell the seals separately, but he doesnt know if the seals come with the bearings either...the bearings are separate parts, at £18 each apparently.
Re: Head bearing
this kit I got from WEMOTO had seals, I dont remember if it was Kyoto, but that rings a bell. I would be 90% sure any kit will come with seals, as you cant use teh ones already on teh bike, they are the wrong shape
