Page 1 of 1
EPS fuel saver
Posted: Sun Aug 14, 2011 1:04 pm
by Jazzscot
My Mrs found this on the interweb and asked me if its true? I said I didnt know but I may know a few guys that do.
Is the science correct or is it just a load of bollox??
Motorcycle Fuel Saver
The EPS Fuel Saver is a fuel economiser and pollution reduction device which utilises magnetic hydrodynamic technology to improve the combustion of hydrocarbon fuels. Mostly, engine combustion is incomplete due to the molecular clusters of hydrocarbon fuel. In normal cases, only about 70% of the total burnt fuel provides the real power, with 30% of the fuel wasted and carbonised.
The EPS fuel saver is the solution to this problem. When the fuel is passed through the fuel saver, the hydrocarbon molecules are temporarily ionised and create positively aligned molecules (P.A.M). The ionised hydrocarbon fuel results in a complete combustion when in contact with the negative oxygen (air-fuel mixture).
The growing population of motor vehicles contributes to air pollution worldwide. Our field trials clearly indicate that the Fuel Saver can help in reducing up to 30% of carbon and other toxic emissions.
Why should you buy one?
* 12% - 20% savings on fuel consumption (guaranteed).
* 15% - 30% reduction in CARBON emissions.
* 25% - 35% reduction in HC emissions.
* Reduced engine vibrations and improved performance.
* Rapid return on investment.
* No alterations to the engine or the fuel line.
* Simple one time installation.
* Environmentally friendly.
Installation
The installation of the EPS Fuel Saver is very easy. Simply clip the Fuel Saver on to the fuel line, close to the fuel injector rail, and secure it in place (at both ends) using the cable ties provided. Please see 'Installation' section for further clarification.
Size
Weight: 60 grams
Size: 45x38x30 mm (1.7x1.5x1 inches)
http://www.epsfuelsaver.com/
Re: EPS fuel saver
Posted: Sun Aug 14, 2011 2:17 pm
by Miztaziggy
Sounds like rubbish to me.
Ionising fuel would use a lot of energy, which must come from the battery or the alternator or somewhere. These electrons removed from the fuel must go somewhere, which, according to this sounds like they are ionising the oxygen too. An ionised oxygen atom is -2 but to create that, you need to split the oxygen molecule and provide electrons, which will come from the electrons removed from the fuel, but which again involves a lot of energy and something attached to the air intake, or possibly the carb? I dont know, but from reading their website, the EPS sounds like a pair of magnets attached to your fuel line, which neither have the power or the strength to ionise anything. To ionise something you need to be firing electrons at it, like in an old TV tube, or you need to be adding enough energy to the atoms so that the electrons can escape the atoms.
Whatever it is they are selling is a set of magnets around a fuel tube. They apparently somehow affect the fuel and polarise the molecules so that (im guessing here) when they enter the carb they repel away from each other and you get a better mixture.
Still not sure how all this is 'supposed' to work, because fuel such as hydrocarbons are not magnetic anyway, though maybe a magnetic field will affect them some other way.
Re: EPS fuel saver
Posted: Sun Aug 14, 2011 3:38 pm
by simo
Bio-Flow is one i used 20 years ago on a Toyota Land Cruiser and a Range Rover after that. It definately made them pull better and run smoother,but don't know about fuel saving, I think not. They are available to attach to your heating boiler either gas or fuel oil. I don't use mine on vehicles any more but on the gas pipe into the heating boiler and I'm sure it works on this as I now have the thermostat turned down a few notches for the same heat output. :thumbup:
Re: EPS fuel saver
Posted: Sun Aug 14, 2011 4:10 pm
by Furrybiker
When these last reared their head I was working for the AA, the motoring one! We were asked this question fairly regularly. After one call I contacted the technical department to get the answer, and was told "I cant believe you work for this organization and are asking such a stupid question"
I took it as a no.......... 8O
Re: EPS fuel saver
Posted: Mon Aug 15, 2011 7:51 pm
by AMCQ46
Furrybiker wrote:When these last reared their head I was working for the AA, the motoring one! We were asked this question fairly regularly. After one call I contacted the technical department to get the answer, and was told "I cant believe you work for this organization and are asking such a stupid question"
lol, that says it all.............its like those balance enhancing bracelets they sell.......how could they work
Re: EPS fuel saver
Posted: Mon Aug 15, 2011 10:20 pm
by tony.mon
Maybe it worked better on leaded fuel, as metals are more likely to be susceptible to magnetism.
Would a better magnet make it quicker?
Re: EPS fuel saver
Posted: Tue Aug 16, 2011 11:55 am
by Steve6088
If this did anything, you'd expect car manufacturers to fit them as standard with this push towards efficiency. As far as I'm aware nobody does.
Re: EPS fuel saver
Posted: Wed Aug 17, 2011 9:27 pm
by sirch345
Jazz, I have an excellent idea. Seeing as your good Mrs found this, perhaps she would like to try it out herself and report back to us. Then if it works we can all get one :wink:
Re: EPS fuel saver
Posted: Wed Aug 17, 2011 9:58 pm
by Jazzscot
Im kinda getting the picture :lol: :lol: :lol:
IT'S A LOAD OF BOLLOX!!!
I think Ill put a brick in the tank and save a bit of fuel that way.
Re: EPS fuel saver
Posted: Mon Aug 22, 2011 9:00 pm
by Darknomad
i dont know bugger all about anything but
even if it did affect the fuel somehow how would you save fuel on it
without re-jetting and balancing the carbs fuel mixture department?
wont you just have funky fuel being used instead of normal fuel at the same rate?
Re: EPS fuel saver
Posted: Tue Aug 23, 2011 6:22 pm
by Pete.L
This thingy had me interested.
It's just about sciency enought to capture my imagination and then it gets you wondering if it really could work. Molecule alignment, hydrocarbon burn efficiency, morecomplete fuel atomisation. Phew! all good stuff 8O
Then I was shopping down town and an instore infomercial just happened to catch my eye. Guess what.... did you know if you put two powerful maganets around your incoming water main pipe you get softer water? Apparently it tastes better and wont clog up your kettle. 8O Sound familiar?
And there I was thinking the answer to the universe was 42. Should have known it 's really just two big bloody magnets. :Ball Kick:
Re: EPS fuel saver
Posted: Tue Aug 23, 2011 6:59 pm
by Stratman
I remember a similar device that my father was tempted with for his Vauxhal Victor in 1963. Nothing new under the sun. Oh, btw, it didn't work.
