![Image](https://lh3.googleusercontent.com/-bNr-Aiv0E4s/S3hgGLCSryI/AAAAAAAAApU/O36vOTAhidU/s512/abba%252520stand.jpg)
![Image](https://lh3.googleusercontent.com/-30dtB-UyHvQ/Tl6daRHnFOI/AAAAAAAABa4/BwLNkF6heyY/abba.png)
The vertical parts are 600mm long and the horizontal is 510mm. These are made using 50mm boxsection
I think I used 18mm threaded rod. The nut was welded 70mm from the top of the vertical I did one on both sides.
I used 20mm box section to make the legs. These were mounted 220mm from the bottom. The angle was a bit hit or miss but you dont want it leaning too far back or too upright (the pic should give you an idea)
You need to grind the threaded rod to a point so it fits inside the hollow on the frame nut thingy
The 17mm socket is welded to the other threaded rod
the socket fits on the nut on the other side of the frame.
I also welded some metal bar to the threaded rod as handles.
Hope this helps.
The welds have since been tidied up with an angle grinder but are still holding strong.
![beer :beer:](./images/smilies/beer.gif)
Jazz
