Marine Grease
vtryorks
Marine Grease
Post by vtryorks »
This might be a common thing, but has anyone thought of or actually used marine grease for wheel bearings?
Any comments or suggestions?
simo
Re: Marine Grease
Post by simo »
As long as it's high melting point grease,but my VTR has sealed bearings :biggrin
Theres A Hare in The Turnips.
Re: Marine Grease
on my off road bikes I take one seal out and fill with waterproof grease before fitting new wheel bearings.
they still need changed every year, but I feel like I am adding value!!!!!
Also avoid pressure washing anywhere near bearings, that causes more failed bearings than anythink else
darkember
Re: Marine Grease
Post by darkember »
Also keep WD40 well away from them
vtryorks
Re: Marine Grease
Post by vtryorks »
Havent got to inspecting them yet but the clown who had the bike previously installed the axel backwards, so god only knows what I'll find.
Everything is completely dry too, I think I'm going to have to do a full strip down.
Thanks fellas.
simo
Re: Marine Grease
Post by simo »
VTRYorks,How do you mean , put the axle in backwards?
vtryorks
Re: Marine Grease
Post by vtryorks »
It had just been inserted the wrong way around, so to undo it I had to use the 22m bolt on the right side (viewed from rear) as opposed to the left, where it should be.
If I'm correct, there should be a 27mm nut on the right hand side and a 22mm on the left under normal circumstances.
I'm not even sure it matters but I'm going to need to be very careful on re-assembly just in case there was a reason for it. I have blade wheels on.
Re: Marine Grease
Thank god, I thought you meant this:
