ignition control unit
muppet
Post by muppet »
am i correct in thinking the control unit gives each coil a 12v supply pulse to fire the coil ? as the other wires are a common ground (Green) :confused
Re: ignition control unit
it sends a common pulse to both coils at the same time.
not a separate pulse for each cylinder.
lost spark jobby, like most bikes.
ive got a spare one if yours is fkt.
muppet
Post by muppet »
Hi benny, do you mean common pulse as in negative pulse or common pulse as in joint pulse, the haynes cct diagram shows it as a joint green ground wire to both coils then 2 seporate pulse wires from the converter unit blue/yellow and yellow /blue i think ?.if it was a negative being switched then the other connection on the coil would have a 12v pos present with ignition on which it doesnt, ive not got any probs with mine i was looking at fitting a dyna two step rev limmiter and they have to be connected to the switched signal on the coil which has been a positive on other bikes i have fitted them on. Hope all this makes sence :crazy:
You might want to consider fitting stick coils while you're there.
Saves a bit of weight, but TBH I didn't notice any performance benefit.
mik_str
Post by mik_str »
tony.mon wrote:You might want to consider fitting stick coils while you're there.
Yep, 0.8 lbs to be exact.....
That's two pies.....
