Head gaskets
Steve6088
Head gaskets
Post by Steve6088 »
I chickened out and got a mechanic to change my leaking head gasket in the end. He only charged me £70, so not too bad.
He mentioned to me that as the standard gasket is made of two layers, I could just fit one of the layers and increase compression. This would have the same effect as getting the cylinder head ground down.
Has anybody tried this?
budd
Re: Head gaskets
Post by budd »
I'd guess multi layer gaskets are like that for a reason, so spliting it may not be a good idea, although I may be wrong and it'll be perfectly fine, but I'd say if you want to increase compression then skim the head,
Storm is now gone :cry: .
Re: Head gaskets
+1 on this idea, I think the two layers sandwich some gasket material.
After all, you've already had a leaking gasket....
But if you're determined, you can strip the engine, and using a piece of flat glass and some grinding paste, get a perfectly flat surface on both the top of the cylinder and the base of the ehad.
Then assemble using a tiny smear of silicon sealer.
But it's MUCH easier to deck the heads.
